Question - KYB AGX on SH
Old Aug 25, 2005 | 12:14 AM
OxYi's Avatar
Default Question - KYB AGX on SH
I just want to make sure that I got the right application, so if I would get
the AGX for base, i just need to get like eibach or neuspeed spring , then im set
right ? any other part that i should get ?
thanks a lot guys !
Old Aug 25, 2005 | 01:06 AM
BB4vTak's Avatar
Default Re: Question - KYB AGX on SH (OxYi)
set yes.. but you should look intoa camber corretion kit as well.. or get used to replacing rubber
Old Aug 25, 2005 | 02:14 AM
TimeRacer's Avatar
As long as you get aftermarket springs for a base you're fine.
Old Aug 25, 2005 | 04:56 AM
Tomakit's Avatar
Default Re: Question - KYB AGX on SH (BB4vTak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB4vTak &raquo;</TD></TR><TR><TD CLASS="quote">set yes.. but you should look intoa camber corretion kit as well.. or get used to replacing rubber</TD></TR></TABLE>
No. If you just lower w/ neuspeed or eibach (~1.5") you don't need a camber kit. Just get an alignment and straighten out your toe and you'll be fine. Toe in/out chews up tires much faster than neg camber will.
Old Aug 25, 2005 | 05:59 AM
Tomakit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OxYi &raquo;</TD></TR><TR><TD CLASS="quote">I just want to make sure that I got the right application, so if I would get
thanks a lot guys ! </TD></TR></TABLE>
Someone correct me if I'm wrong, but aren't SH shocks slightly shorter than base shocks?
meagainsttheworld
Jul 9, 2007 08:42 PM
Tokyosmash!
Honda Civic (2006 - 2015)
13
Jun 19, 2007 07:08 PM
LS1powered
May 24, 2007 04:07 PM
ezol
Jan 6, 2007 03:30 PM
goofyej6
18
May 27, 2004 05:06 PM
