itr camshafts or ctr camshafts!!! which is better
Old Aug 24, 2005 | 11:12 PM
teamvirus's Avatar
My car breaks a lot!
Default itr camshafts or ctr camshafts!!! which is better
i have a 99 civic si....i was wondering which cam would be better in a all motor setup itr or ctr
Old Aug 24, 2005 | 11:15 PM
midwesta's Avatar
they are the same things. just depends on the year of the ITR cam.
Old Aug 24, 2005 | 11:18 PM
ceLtic*
Guest
Posts: n/a
Default Re: (techintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by techintegra &raquo;</TD></TR><TR><TD CLASS="quote">they are the same things. just depends on the year of the ITR cam.</TD></TR></TABLE>
newer years had a higher lift or duration. i forgot....the difference is MINIMAL and should not bias your decision to purchase either cam. $$$ should.
Old Aug 25, 2005 | 02:07 AM
808_si's Avatar
just get the ctr cams so you don't have to worry about getting the right year for the ITRs...
Old Aug 25, 2005 | 04:32 AM
b204dr's Avatar
Default Re: (808_si)
wrong the ctr intake cam is better than an itr cam while exhaust remained the same !
Old Aug 25, 2005 | 05:28 AM
gapergurlie_18's Avatar
Default Re: (b204dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr &raquo;</TD></TR><TR><TD CLASS="quote">wrong the ctr intake cam is better than an itr cam while exhaust remained the same ! </TD></TR></TABLE>He is right... i think that could be searched.... i saw it the other day in the archives
Old Aug 25, 2005 | 05:52 AM
b204dr's Avatar
Default Re: (gapergurlie_18)
Integra Type R 11.5 mm, duration - 240 @ 1mm 10.5 mm, duration - 235 @ 1mm
Civic Type R 11.5mm, duration - 243 @ 1mm 10.5 mm, duration - 235 @ 1mm
integrasi
Aug 24, 2004 11:53 AM
PowerHouse
Apr 6, 2004 10:39 PM
aandDavidsaid
Mar 27, 2004 12:38 PM
Dammit_Dan_954
32
Dec 14, 2003 08:46 AM
sdchump
Oct 17, 2003 05:34 AM
