Flare wrench for brake lines...
Old Aug 24, 2005 | 09:44 PM
unknown0001's Avatar
Default Flare wrench for brake lines...
Hey guys, I'm swapping in rear integra disc brakes tomorrow and would like to just clarify that the only flare wrench to use is a 10mm.
Is that correct? what about the soft lines do I use a normal wrench for those or do I still use the flare wrench?
thanks
Old Aug 24, 2005 | 09:49 PM
nub.96ek's Avatar
Default Re: Flare wrench for brake lines... (Mr.RHTuner)
Use a flare wrench for ALL brake line/valve fittings... it's the safest way to go!
Old Aug 24, 2005 | 09:53 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Hey guys, I'm swapping in rear integra disc brakes tomorrow and would like to just clarify that the only flare wrench to use is a 10mm.
thanks</TD></TR></TABLE>
I'd use a flare wrench on all of the lines just to make sure you don't strip them..
10mm.
Old Aug 24, 2005 | 09:54 PM
PINEAPPLE's Avatar
Without the flare wrench you will learn the hard way and find out that with regualar open wrenches actually strip the lines!
Old Aug 24, 2005 | 09:55 PM
PINEAPPLE's Avatar
Default Re: Flare wrench for brake lines... (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">
10mm.</TD></TR></TABLE>
lol beat me to it.
Old Aug 24, 2005 | 10:00 PM
Jimmy's Avatar
Global Moderator
Default Re: Flare wrench for brake lines... (PINEAPPLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINEAPPLE &raquo;</TD></TR><TR><TD CLASS="quote">
lol beat me to it.</TD></TR></TABLE>
hahaha.
Old Aug 24, 2005 | 10:08 PM
1.8EG-T's Avatar
Yeah, I learned the hard way on my DA...
Old Aug 24, 2005 | 10:56 PM
BlueIntegraBoy's Avatar
I used a flared wrench for the soft line. Then attempting to remove the prop valve, it started stripping. I used a closed end to bleed the line though cuz the flared wrench started to free spin.
Old Aug 25, 2005 | 07:50 AM
Default Re: Flare wrench for brake lines... (BlueIntegraBoy)
ok but on the MC/BB/prop valve I'm gussing the flare wrench size is 10mm correct? any ideas what the size is for the flex brake lines? Just wanting to know so I can buy the wrenches before I begin
Old Aug 25, 2005 | 07:55 AM
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">ok but on the MC/BB/prop valve I'm gussing the flare wrench size is 10mm correct? any ideas what the size is for the flex brake lines? Just wanting to know so I can buy the wrenches before I begin</TD></TR></TABLE>
They should all be 10mm.
Old Aug 25, 2005 | 12:36 PM
Sketch_hs's Avatar
blah, grab some vice grips. works everytime
Old Aug 25, 2005 | 12:40 PM
seannabend's Avatar
Default Re: (PINEAPPLE)
it is still possible to round off a fitting with a flare nut wrench... it happened to me and it wasn't because I was using the wrong size wrench either
put some penetrating oil on there and make sure all the undercoating is cleaned off of the fittings before you start wrenching on them
good luck
Old Aug 25, 2005 | 12:47 PM
IHateJDM's Avatar
Default Re: (seannabend)
all mine were 10mm, but i've never seen a 10mm flared nut wrench that didn't have a 12mm on the other side.
Old Aug 28, 2005 | 05:41 AM
Fuster_Cluck's Avatar
Default Re: (IHateJDM)
I'm going to be pulling rear discs off my LS soon.....
If you are interested: http://www.harborfreight.com/c...=5126
Should be good enough since I would not expect the lines to be torqued to 80ft/lbs.
Any tips for removing the brake system?
jdm_dc_199
Sep 10, 2007 11:31 PM
kndaqikEG
May 14, 2005 10:56 AM
scoobyghost
Jun 7, 2003 08:36 PM
