what catalytic converter do i need?
Old Aug 24, 2005 | 09:08 PM
driftt's Avatar
Default what catalytic converter do i need?
ok, i have a 92 accord ex with a h22 swap in it and i need to know what i need to do for a converter. im hoping there is one that will bolt right in and not need to be cut and welded and such.
i am using the h22's a-pipe. so im guessing the cat i need has to come off a prelude of some type cause it had the kinda offset 3 bolts on the a-pipe rather then the 2 with the accords.
also i am using an exhaust off of a 5 gen accord which is a little longer at the b-pipe i believe but that shouldnt be a problem, ill just need whatever cat would be used for an h22 swap into the 5th gen accord.
so can anyone tell me what i need to use here? i would like to be able to use the h22's a-pipe.
sorry if this sounds confusing.
Old Aug 25, 2005 | 07:43 AM
driftt's Avatar
Default Re: what catalytic converter do i need? (driftt)
anyone?
Old Aug 26, 2005 | 05:35 PM
driftt's Avatar
back like cooked crack.
Old Aug 26, 2005 | 06:44 PM
The_Todd's Avatar
Farts in the shower
I know people have used prelude cats and had accord exhaust...only thing that needs to be 'fabbed' would be the connection which any compentent welder or exhaust shop should be able to do .
Old Aug 26, 2005 | 06:50 PM
driftt's Avatar
Default Re: what catalytic converter do i need? (.ken)
so what you're telling me is there is no bolt in solution most likely correct?
Old Aug 26, 2005 | 07:04 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driftt &raquo;</TD></TR><TR><TD CLASS="quote">so what you're telling me is there is no bolt in solution most likely correct?</TD></TR></TABLE>
Not that I have read. I know a lot of people have had problems with the h22 header/downpipe going into an accord exhaust and custom pieces were needed. I would say get a prelude cat then get a custom piece or flange made to bolt to the exhaust.
Old Aug 26, 2005 | 07:30 PM
driftt's Avatar
gotcha, thanks alot man
BrandonShaq
Jan 31, 2016 08:39 AM
tkhang
Jul 10, 2010 02:05 PM
minitruckin4life83
Sep 10, 2005 03:51 AM
superslowhatch
Jun 23, 2002 07:29 PM
