integra front sway bar
Has anyone installed a integra front sway bar on a 92-95. I just tried to intall a 24 mm integra fromt bar and it hit the frame. I also have no mounting spots for the bushings? I thought iy was a bolt on affair and what do I do about the lack of mounting holes for the say bar bushings? help?
I have 22mm and 24m integra front sway bars. There apears to be nowhwere to bolt up the bushings? The bar also hits the frame when it makes it's first turn where the bushing bolts up? very confused. I wish someone could show me pick of a integra front sway bar on a eg? This is supposed to be a bolt up deal. help/
problem is the bar is hitting the frame where it comes off the endlinks at the thePLEASEfirst bend. does the car need to be on wheelstands? PLEASE help with underside pics. and i took the teg bar out and now can't find where the bushings mount/ help. WHO HAS TEG FRONT BAR? CAN YOU SHOW ME INSTALLED PICS? very frustrated. help
What are you really doing here? Explain why it's not working.
I assume you have the car on jackstands, the exhaust and shift linkage disconnected. You need to slide the sway bar under that stuff.
someone help this man out, anyone have a good how to install a front sway bar with good pics please pm me if you have a link about to do mine just want to make sure i have everything needed thanks
First of all, do you have the correct LCAs? Sounds as if you dont since you cant find a spot for the endlink bushings, as for hitting the frame? dont know on that one, but without the correct LCAs aint gonna matter much.
Also, make sure you arent putting the bar in upside down, maybe thats why you are hitting the frame.
Modified by 4door_demon at 11:03 AM 8/25/2005
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4door_demon »</TD></TR><TR><TD CLASS="quote">First of all, do you have the correct LCAs? Sounds as if you dont since you cant find a spot for the endlink bushings, as for hitting the frame? dont know on that one, but without the correct LCAs aint gonna matter much.
Modified by 4door_demon at 11:03 AM 8/25/2005</TD></TR></TABLE>
LOL.. .That remind me of that guy that put on his omni front upper control arm upside down.
CBURKE
18
Aug 18, 2005 10:33 AM
