Suspension & Brakes Theory, alignment, spring rates....
help with integra sway bars on 92 4 door?
Old Aug 24, 2005 | 07:46 PM
4potnick's Avatar
Default help with integra sway bars on 92 4 door?
I was under the understanding that 94+ integra sway bars are a dirrect bolt on with correct lower control arms. I am having problems. there seem to be nowhere to bolt the bushings and the bar hits the frame? Am I doing something wring or is a intregra front sway bar not bolt in eg's, not to mention no holes for the sway bat bushings? what do I do? help it's midnight and IO have to be to work at 10am?
Old Aug 24, 2005 | 08:25 PM
4potnick's Avatar
Default Re: help with integra sway bars on 92 4 door? (4potnick)
top
Old Aug 25, 2005 | 05:06 AM
4potnick's Avatar
help
Old Aug 29, 2005 | 08:41 PM
thisisntjared's Avatar
um it does work. i just finished the installation a few days ago. you have the integra lcas, swaybar and bushings right? including the bushings for the lcas? cus the bushings for the swaybar both into the mount for the bushings for the lcas and then also to the subframe for which there should already be a hole with a nut spotwelded to the inside.
nomoshing
Dec 17, 2009 02:54 PM
4potnick
13
Aug 26, 2005 05:29 AM
hazard_one
Suspension & Brakes
May 18, 2005 01:59 PM
PabloDiablo
Apr 1, 2004 05:30 PM
accordfreak
Mar 31, 2004 08:27 PM
