Full boost making a weird noise.
Old Aug 24, 2005 | 06:48 PM
SlowB16si's Avatar
Default Full boost making a weird noise.
Well I finally got my car running and when I take it to full boost it makes these weird fan hitting type of noise. The turbo only has 1500 - 2000 miles on it. Its not a detenating sound or pinging sound. Is it my turbo bearings or shaft or what could it be?
Old Aug 25, 2005 | 02:51 AM
SlowB16si's Avatar
Default Re: Full boost making a weird noise. (SlowB16si)
up
Old Aug 25, 2005 | 05:55 AM
boosted k20's Avatar
could it be wastegate opening up?
Old Aug 25, 2005 | 06:33 AM
fast93accord's Avatar
fan hitting noise??? sounds like compressor surge to me...
if so, the turbo is spooling too fast for the engine to breathe it in...
Old Aug 25, 2005 | 05:39 PM
SlowB16si's Avatar
Default Re: Full boost making a weird noise. (fast93accord)
I was thinking it could just be the wastegate opening up. Ive never heard an open wastegate noise is it a really metalic sound? It sounds liek metal to me though, is that what the wastegate sounds like open?
Old Aug 25, 2005 | 06:21 PM
B6tPoweredMx3's Avatar
Would you call it a "howling" or a loud whistle type sound?
Old Aug 25, 2005 | 06:35 PM
93turbo16's Avatar
sounds like a wastegate to me.
Old Aug 25, 2005 | 06:52 PM
Haleiwa-Brando's Avatar
Default Re: (93turbo16)
Have you bothered to let the car run, and stick your head in the engine bay to get a visual and to try and pinpount the sound?
Watch the turbo, see and listen for this 'metal on metal' sound. Try and confirm the issue
Old Aug 26, 2005 | 08:43 AM
fresh pizza guy's Avatar
$4500 in a D series
does it sound like tin foil crackling?
Old Aug 26, 2005 | 09:27 AM
dunkd's Avatar
I would best describe the wastegate opening as a really big exhaust leak - cuz thats pretty much what it is.
Old Aug 26, 2005 | 09:33 AM
SOHC_MShue's Avatar
Default Re: (fresh pizza guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fresh pizza guy &raquo;</TD></TR><TR><TD CLASS="quote">does it sound like tin foil crackling?</TD></TR></TABLE>
you've experienced that a few times right
Old Aug 26, 2005 | 10:26 AM
ginoboy1978's Avatar
My first turbo did that. I had to get rid of it.
Does it sound like a saw cutting through metal?
When my turbo was doing that, we found out that the turbine wheel was hitting the housing (there were grooves being made in the housing). Worst part was, i found that out on the dyno when it was getting tuned.
However, my turbo was not creating ANY boost at all.
Lets hope that its not the same case with you.
DAN
Old Aug 26, 2005 | 08:38 PM
Jared's Avatar
what turbo?
autoluder
Jun 13, 2008 07:23 AM
juniestyle
Apr 11, 2007 08:22 PM
SinSeven
Apr 16, 2003 11:09 AM
sunscreen
Jul 2, 2002 05:40 PM
hawjboi
Jun 28, 2002 07:43 PM
