B16 Vacuum Line diagram
Old Feb 24, 2002 | 07:07 PM
EP3_05's Avatar
Default B16 Vacuum Line diagram
I am throwing a code 5-> MAP Sensor. In my shop manual it says that it is either a mechanical problem or incorrectly routed or unplugged vacuum hose. I am leaning more towards the later since I only had a vague idea of which lines to hook up and which ones to cap. If someone has a pic or a diagram of how to connect the lines I would greatly appreciate it.
Old Feb 24, 2002 | 08:15 PM
AbaZ's Avatar
Default Re: B16 Vacuum Line diagram (91civic)
what a shittie pic, its not mine... aight, their are 2 sensors on the firewall/bulkhead. 1 says map sens, find the bottom of it and connect that vaccume line to the right hand port off the t-body (one that has manifold pressure)
Hope that helped.
Old Feb 25, 2002 | 04:23 AM
EP3_05's Avatar
Default Re: B16 Vacuum Line diagram (AbaZ)
Thanks. That helped some. Anybody else have a better pic??
Old Feb 25, 2002 | 06:43 AM
EP3_05's Avatar
TTT...come on someone has to have a pic....
Old Feb 25, 2002 | 07:15 AM
SiR831's Avatar
i actualy didn't use eric B's vacuum diagram! I used any vacuum port and my car was running like ****. I then tested some of the vacuum ports to see which one was providing the most vacuum. And just plugged my map sensor there. And the car ran like a champ!
Old Feb 25, 2002 | 07:17 AM
EP3_05's Avatar
Default Re: B16 Vacuum Line diagram (SiR831)
Thank you very much. I was planning on doing that but I wanted to see if anyone had a pic or diagram.
Old Feb 25, 2002 | 07:35 AM
Count Blah's Avatar
From: A place where stupidity runs rampant aka NorCal
The map connects to the smaller nipple on the top of your throttle body. The larger nipple on your tbody connects to the lower of the 2 nipples that are together on the charcoal canister. All my pics dont show it well enough or else i would post one for u!
-Todd
civicflow
16
Jun 7, 2007 10:50 AM
xci_ed6
Aug 10, 2002 05:35 PM
B20zvtecek
May 1, 2002 07:45 PM
