what motor mounts is recommended
oe honda are always good. urethane inserts keep things solid, but might squeak. up to you, and it depends on the purpose of the car. daily driver, track car, etc. get what you can live with
I filled mine with 3M Windo-weld, i'm very satisified with the results. The motor is in very solid and cabin vibration is only felt at idle, even then, it's not bad at all, just noticeable.
yes oem mounts are good if u dont wanna spend too much. i got OE GSR mounts with urethane inserts. its quite solid, put ur foot on the motor and give it a good push to make sure it doesnt move. a other good brand is HAsport motor mounts.
The Hasposrt mounts are the way to go...I suppose you could go wtih a cheap copy of them, as they are out there, but hasport mounts are warrantied for life.
dafreeeze
19
May 14, 2013 04:33 PM
