Suspension Technique Springs (do i need a camber kit?)
Old Aug 24, 2005 | 02:02 PM
dtrtw's Avatar
Default Suspension Technique Springs (do i need a camber kit?)
Hi i got the suspension techniques springs i know they have 2 different ones for the dc2 integra i think i got the ones that are the lowest im not sure i think it's a 2" drop but cant be positive would i need a camber kit on my car? i did spin out once already and did hit the wall but im not sure if it's cause i didnt have a camber kit on my car please let me know thanks guys
Old Aug 24, 2005 | 02:16 PM
nighthawkgsr's Avatar
Default Re: Suspension Technique Springs (dtrtw)
yeah it would be best to get a camber kit put in your car. i also have a two inch drop on my car and i used a skunk 2 adjustable camber up front. imo putting a camber kit on a lowered car is a must. it will save you money from replacing your tires and put less stress on your axles.
Old Aug 24, 2005 | 02:22 PM
dtrtw's Avatar
Default Re: Suspension Technique Springs (nighthawkgsr)
i dont even know a shop that can do the install on the kit is it hard to do? and how do you adjust it so you can have it at 0 camber?
Old Aug 24, 2005 | 04:31 PM
chinese acrobat's Avatar
Don't go with Skank2
Heard lotta BAD things bout them.
If it's 2'' drop you'll have to get a camber kit
Go to http://www.specprod.com The BEST kit on the market. Kinda expensive though.
Old Aug 25, 2005 | 08:14 AM
Default Re: (chinese acrobat)
BASICALLY the skunk 2 ones replace your oem camber plates with new ones with a adjustable joint. these pieces slid and are tightened down with allen wrenches. you would still need to go get a wheel alighment before your finally tighten it down. you probably won't get 0 camber around but its close.
Deo
12
Sep 15, 2005 09:49 AM
OdysseyHF
Nov 22, 2004 09:29 AM
lazyxazianxboi
Nov 1, 2004 08:32 AM
IloveNewt
May 5, 2003 10:24 AM
CC2
Dec 1, 2002 09:52 AM
