HELP - Rusted Bolts and Dirty A$$ Bay
Old Aug 24, 2005 | 01:50 PM
HBADGE's Avatar
Default HELP - Rusted Bolts and Dirty A$$ Bay
I know I can use degreaser and such...but should I just change bolts and are there any other kind of solutions to clean this..................
So whats the best idea???
Old Aug 24, 2005 | 01:52 PM
Jimmy's Avatar
Global Moderator
Try some polish, replace the rusted *** nuts, scuff with some sandpaper and if you have access to a sandblaster take the parts off and blast them..
Old Aug 24, 2005 | 01:56 PM
JunY's Avatar
Default Re: (Jimmy)
Sand paper, WD 40, Liquid wrench, few new nuts and bolts, wire brush, metal polish, simple green, and etc.
Old Aug 24, 2005 | 02:12 PM
pdiggitydogg's Avatar
Theres no real point in cleaning the rusted nuts and bolts - they will look the same after a few months anyway. The only way around it, would be to replace them all with stainless steel fasteners of the same grade
Old Aug 24, 2005 | 02:20 PM
AutoXer's Avatar
Default Re: (pdiggitydogg)
Yeah, you're in Ontario. Nothing you can do about it. Just keep it clean, and don't worry about the rust.
Old Aug 24, 2005 | 03:05 PM
midwesta's Avatar
just swap it. lol
but yeah, dont go all crazy and end up ruining stuff and making the car undriveable
Old Aug 24, 2005 | 03:30 PM
Civicse's Avatar
Default Re: (techintegra)
if it really matters that much to u, u can replace it, but i also live in ontario and will most likely just rust up again, its prolly mostly only on the surface
Old Aug 24, 2005 | 04:01 PM
chinese acrobat's Avatar
Wire brush attachment on a dremmel or other rotary tool and valvoline sythetic lube.
Old Aug 24, 2005 | 05:00 PM
nota-eg's Avatar
Default Re: (chinese acrobat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chinese acrobat &raquo;</TD></TR><TR><TD CLASS="quote">Wire brush attachment on a dremmel or other rotary tool and valvoline sythetic lube.</TD></TR></TABLE>
I was going to reccomend a battery terminal cleaner (wire brush) and mabe painting them or putting some antiseize on them.
SHG_Claudio
Jan 8, 2009 02:47 PM
Fuster_Cluck
Paint and Body
22
Jun 6, 2007 06:26 PM
Carbcivic
Apr 22, 2006 03:26 PM
WayQuiz
Dec 31, 2005 03:59 PM
