wiring plx300 wideband to ecu
Old Aug 24, 2005 | 01:50 PM
5thGenFanatic's Avatar
Default wiring plx300 wideband to ecu
hi i did a b-swap into my 92 4 door civic and bought the plx300 wideband a/f monitor... i just wanted to know if anyone could tell me where to wire the gray and white wires to the ecm so i can replace my stock o2 sensor.. or send me a link to the entire procedure...the instructions included were 1 paper and they suck... thanks
Old Aug 25, 2005 | 12:01 AM
rjay8604's Avatar
Default Re: wiring plx300 wideband to ecu (jdmspecb18)
Go to PLX website plxdevices.com and they have tech support. you can wire the narrowband (gray i believe) into the stock ecu signal location. Since i use neptune, i feed the ECU the wideband signal (white).
Old Aug 25, 2005 | 03:36 AM
Default Re: wiring plx300 wideband to ecu (rjay8604)
bump
Old Aug 25, 2005 | 11:38 AM
deftones0817's Avatar
you wire it to d14. on obd1 car. grey if you want it to read narrow band readings to ecu like stock o2 sensor or white if you want to send wideband signal to ecu for datalogging a/f. hope that helps
Old Dec 30, 2009 | 07:55 PM
jlfrnce's Avatar
what do you wire the wire wire on on the Neptune RTP system? I can get my hands on a Innovate system but i have read it was junk but i want my tunerview II to show are fuel, If i am in wrong area i am trying to do seaches, but thanks for help in advance
Treyschls
Dec 11, 2014 07:49 PM
the.hamburglar
May 3, 2006 08:11 AM
5thGenFanatic
Sep 6, 2005 06:48 PM
5thGenFanatic
16
Aug 28, 2005 05:38 PM
Tampa94lsteg
Oct 8, 2004 08:28 PM
