GSR Crank & LS block
Old Aug 24, 2005 | 06:54 AM
EF9SIRJeff's Avatar
Default GSR Crank & LS block W/ B16 pistons ?????
can i use a GSR Crank In a LS block i cant remember for the life of me or would that kill my compression ????????????????
i have a LS that i am rebuilding the bottom end on to put in my car
I thought about putting in B16 Pistons with a GSR crank and dont know what rods to use (prolly eagle) but if i were to use OEM rods what should i use
Oh also will b16 pistons work with an LS head or would the Compression be too High ????
Or if i should even use the GSR crank and stick with LS crank ?????
Old Aug 24, 2005 | 06:57 AM
CRX Toad's Avatar
Default Re: GSR Crank & LS block (EF9SIRJeff)
Yes you can but the LS has a longer stroke than the GSR.
Old Aug 24, 2005 | 07:02 AM
91civicDXdude's Avatar
use the same rods as the crank. if you use a GSR crank with b16 pistons in an LS block, use eagle GSR rods.
Old Aug 24, 2005 | 11:07 AM
EF9SIRJeff's Avatar
Default Re: GSR Crank & LS block W/ B16 pistons ????? (EF9SIRJeff)
bump
carlossolorzano
May 27, 2012 01:12 AM
jksmith
Nov 3, 2008 11:14 AM
b18psi
Sep 20, 2006 04:15 PM
allaboutdaz
Aug 19, 2006 10:56 AM
Slink2000
Mar 20, 2006 08:50 AM
