Help OBD0-OBD1
Hello I have a OBDO wiring harness in my CRX and i just put a OBD1 singal cam vtech d16z6 in it, and it all worked i change distibuter and manifold and all the wires are good but there is a plug on the thormostat I dont know if i need that, it will not start, it wants to kick over, but i have not checked ecu for a code, but no check engine light is on. anyone that can help that would be great, I might have the timing wrong will that stop it from starting?
I just used the OBDO wiring harness just added a cencur on the block from the si and no im using a SI ecu and used SI intake and exhaust and disturibter, only my wiring haress didnt have a plug for the d16z6 thormostat plug but i dont think that would cause it not to start.
Serdar
16
Sep 6, 2006 09:11 AM
hatchinprogress
36
May 4, 2006 09:16 AM
