Can anyone confirm the prop valve ratios for the various brake setups
I searched and found this:
3030 - 9.5" front / drum rear
3035 - 9.5" front / larger drum rear
3040 - 9.5 front / disc rear
4040 - 10.25" front / disc rear
4035 - 10.25" front / larger drum rear
I'm particularly interested in verifying this one:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg »</TD></TR><TR><TD CLASS="quote">I searched and found this:
3040 - 9.5 front / disc rear</TD></TR></TABLE>
thats with drum in the rear also
heh, that looks like the list I made up a while back.
the '95 SI came with the 3040 prop valve.
it also came with 9.5" front brakes and rear disk.
BUT the master cylinder makes just as much of a difference. Thats part I don't know off the top of my head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 »</TD></TR><TR><TD CLASS="quote">when you push the pedal hard the brakes lock... they should.
do you mean that the front brakes lock before the rear or the rear brakes lock before the fronts?</TD></TR></TABLE>
should be rear before the front cause their gettin more fluid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueTeg »</TD></TR><TR><TD CLASS="quote">No its not.
rear lockup before front = higher potential to spin the car</TD></TR></TABLE>
Just like pulling the e-brake.
Yes, 92-93 Civic Si's have this prop valve.
turbociv910
Jan 12, 2006 10:53 AM
BlueTeg
Aug 29, 2005 09:01 AM
spoolinq
10
Jul 28, 2005 08:54 PM
