civic swap shifter question!!!!help please!!!!
Old Aug 23, 2005 | 06:46 PM
mintscorpion's Avatar
Default civic swap shifter question!!!!help please!!!!
so i have a b16a swapped into my 94 civic ex coupe. i got the integra shift linkage but im using a del sol shifter and for some reason it won't shift right. is it because the del sol shifte is shorter?? i have no idea. if i need a new shifter should i get one from honda or an after market one? i am stuck, this is the last part of my swap to make it work. please help... much appreciated.
Old Aug 23, 2005 | 07:00 PM
damnraz's Avatar
Default Re: civic swap shifter question!!!!help please!!!! (mintscorpion)
I never actually seen a del sol shifter but it might be comparable to the normal single bends that come out of the eg itself if ofcourse it was a sohc model, I'd recommend just getting an ls/gsr shifter for your shift linkage and it'll do you just fine as far as the b16a3 shifter, I wouldn't know.. haven't seen one or used one, I just know my ls shift linkage w/ ls shifter works good
redline870
Feb 14, 2009 11:45 PM
Fibercation
Feb 22, 2008 11:18 AM
PhrequenC
53
Jun 28, 2007 09:57 PM
mrnicolas
17
Sep 13, 2004 08:25 AM
Doctor CorteZ
Jan 28, 2002 07:38 AM
