arp head stud nut size?
Old Aug 23, 2005 | 06:46 PM
B20TDC2's Avatar
Default arp head stud nut size?
i'm trying to get the head off ,and i can't find the right size socket 14mm fits loose 13mm is to small anyone know the exact size. thanks in advance
Old Aug 23, 2005 | 06:47 PM
BlueShadow's Avatar
Default Re: arp head stud nut size? (B20TDC2)
The ARP head studs for my B18C used a 12 point 13mm socket.
Old Aug 23, 2005 | 06:52 PM
B20TDC2's Avatar
Default Re: arp head stud nut size? (BlueShadow)
thanks i'll have to pick oe up tomm.
Old Aug 23, 2005 | 07:01 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20TDC2 &raquo;</TD></TR><TR><TD CLASS="quote">thanks i'll have to pick oe up tomm.</TD></TR></TABLE>
You might wanna get a deep socket one too. and definately make sure it's the <u>12 piont</u> 13mm. If you are using a 6 point 13mm, then that's probably why it's not going on.
Old Aug 23, 2005 | 07:08 PM
B20TDC2's Avatar
yeah i'll deff. grab deep socket.
Old Jun 9, 2010 | 09:21 AM
steveo34609's Avatar
Thank god someone knew this ! lol
Old Jun 9, 2010 | 10:17 AM
95 integra's Avatar
Last I checked ARP uses SAE, so its actually something like 9/16s....12 point.
Old Jun 9, 2010 | 01:28 PM
v.ice1's Avatar
its 1/2 12 point to be exact i have them on my ls and 13 will work but 1/2 is a lil bit tighter and tighter is always better haha
Old Jun 9, 2010 | 02:03 PM
phunhaus's Avatar
Use a 1/2" 12pt socket.
Old Jun 10, 2010 | 08:16 AM
Mikey3000's Avatar
mine was 9/16 12 pt
Old Jun 10, 2010 | 06:13 PM
stumpyf4's Avatar
Agreed that the ARP nuts are SAE, bottom that threads into the block is threaded metric but the top threads are indeed SAE as is the nut.
I remember having to dig into my father's old assed SAE socket set looking for some 12pt. SAE sockets. 1/2" sounds right but I could be mistaken.
Old Jun 10, 2010 | 09:43 PM
95 integra's Avatar
I was thinking 1/2" originally too, however I know I have used the larger 9/16s on something (H22, K20 or potentially a domestic 350)...or they changed them up and now use the larger size. Either way, a 13mm is damn close to 1/2". I've grabbed the 14mm, 6 point too many times before thinking a motor had the stock bolts, in fact that is why my deep well 14mm is broken.
Old Nov 5, 2013 | 06:57 PM
2point2's Avatar
H22 is 14mm 12 point. The nuts have a METRIC thread (look closely at them). 9/16 will work but 14mm fits better.
boosh
12
Sep 13, 2007 06:36 AM
candy eg
Feb 24, 2006 10:53 AM
brinks
May 23, 2004 01:45 PM
InTeGrA B18b1
Apr 19, 2004 09:33 PM
stickshiftt
Jan 4, 2004 10:19 PM
