car won't start!
Old Feb 24, 2002 | 04:30 PM
kilab16a's Avatar
Default car won't start!
Okay, I've done all the troubleshooting and i've come to the conclusion that its the starter. When I turn the ignition, all I get is a clicking noise coming from the ECU area. I tested the battery, its fine. Checked all fuses, Fine. Did the karate kid test (Daniel LaRusso's pushes the car untill his mom says pop it) and it started right up. I drove it about 10 miles today and everything else seems to be fine. I just wanted to ask you knowlegable people if this is indefinatly the starter. I've never heard of an honda ignition going bad and apparently, neither has any of the part stores, Pepboys and Autozone, which means they can't even order them yet. But I assume I can get a late model Delsol b16 or GSR starter easier.
Old Feb 24, 2002 | 05:02 PM
DragII's Avatar
25 Year Member
Default Re: car won't start! (kilab16a)
I took my starter down to pepboys, and they tested it free...you should do the same
only takes 5 minutes to remove the starter....so why not.
Old Feb 24, 2002 | 06:39 PM
kilab16a's Avatar
Default Re: car won't start! (DragII)
kewl, thanks! I'll try that.
Old Feb 25, 2002 | 06:11 PM
kilab16a's Avatar
okay, its not the starter! I'm really getting pissed at this car. My friend told me the only logical thing could be the alarm. I have a starter kill switch feature on my Viper 600. I'm going to take it to Circuit City, where I got it from and hope they can help me.
Old Feb 26, 2002 | 04:13 AM
DragII's Avatar
25 Year Member
also...your battery might not have enough charge....I went through this exact same thing....I ended up bringing my battery to the store...they said it was real weak...so I had them charge it up...car started right up after that.
Old Feb 26, 2002 | 06:13 AM
kilab16a's Avatar
i've done that too. I took it to sears thinking I might get myself a nice Diehard, but they told me the battery was fine. I've checked all fuses, the starter. If its not the alarm, i don't know what it is.
Old Feb 26, 2002 | 10:57 AM
erniecars's Avatar
could be a bad main relay. I had that problem. You can remove the main relay from under the dash and pop it open and resolder the cold solder joints or just buy a new relay for about $50 from the dealer.
Old Feb 26, 2002 | 11:36 AM
Perfectionist's Avatar
Default Re: car won't start! (erniecars)
Main relay trouble wouldn't prevent the car from cranking. I suggest you do a thorough inspection of your battery cables (both ends) for continuity and tight clean connections. When you had your starter tested, did they just check the starter motor, or did it include the starter solenoid also?
Ruling all else out, I would begin checking the starter interrupt switch. In the console if it's an automatic, or above the clutch pedal if it's stick. The next logical thing to check would be the ignition switch itself. Good luck.
Old Feb 26, 2002 | 11:47 AM
aklucsarits's Avatar
New User
We used to have 100k mi+ 1989 Nissan Sentra that had the same problem. We could push start it, but it would not crank. The starter was replaced but that did not fix it. Finally, after like 2hrs with a voltmeter, a garage narrowed it down to a bad relay somwhere... We replaced that and it started like a champ.
Andrew
Old Feb 26, 2002 | 12:20 PM
DragII's Avatar
25 Year Member
Default Re: car won't start! (aklucsarits)
also make sure your alternator, and ground wires are all in tact.
Old Feb 26, 2002 | 02:31 PM
kilab16a's Avatar
thanks guys, you all are the best. I just got done taking it to Circuit city and its not the alarm. They check the volt meter and some other stuff but still nothing. I don't know what else to check. I'll check the relays as you guys said, but it sounds too easy. And with me, nothings too easy.
prelude2001h22a
Nov 22, 2014 02:04 PM
skn181
Mar 23, 2007 06:02 PM
projectPSI
Mar 18, 2005 02:54 PM
DAYUIZ
Jan 20, 2004 03:03 PM
