94 5spd dx - random squealing?
Old Aug 23, 2005 | 06:26 PM
ilu's Avatar
ilu
Default 94 5spd dx - random squealing?
rarely when i drive my car it will make a high pitched squealing noise...i've noticed i can make it stop when i put it in neutral and then put it back in gear, but make sure it's in gear good...it doesn't sound like grinding. just squealing. what's this noise coming from?
Old Aug 23, 2005 | 06:28 PM
damnraz's Avatar
Default Re: 94 5spd dx - random squealing? (ilu)
I think it's time to replace your front brakes, there's a piece of metal that rubs against the rotor when the pads are worn which is supposed to notify you that you're in need of replacing your pads.
Old Aug 23, 2005 | 06:37 PM
ilu's Avatar
ilu
Default Re: 94 5spd dx - random squealing? (damnraz)
it sounds nothing like brake squealing though. it's a lot louder and it doesn't make noise when i brake, it makes noise right when i shift into gear.
Old Aug 23, 2005 | 06:49 PM
mintscorpion's Avatar
does it also squeal when you make sharp turns?? if so, it could be a belt problem
Old Aug 23, 2005 | 07:36 PM
ilu's Avatar
ilu
Default Re: 94 5spd dx - random squealing? (mintscorpion)
no, i've always been going straight when it happened.
Old Aug 23, 2005 | 07:40 PM
Hatch It's Avatar
Turn your AC off and see if it happens....
when i first start my car it makes that exact sound your describing but goes away, it also happens when my ac is on....
good luck
Old Aug 23, 2005 | 07:44 PM
boosted civic 2k6's Avatar
Default Re: 94 5spd dx - random squealing? (Hatch It)
try popping the hood. have someone turn the steering wheel. turn on the ac if u have one. it might be coming from one of your accessory belts. if not then its your brakes? lol. usually on cold days those damn belts screech if not tensioned enuff or worn out.
maybe you need new brakes? does it only happen when you press on the brakes? is it a metallic squeal? then its brakes. or maybe your brake pedal is squeaking like my clutch pedal. lmao. oh well.
Old Aug 23, 2005 | 07:53 PM
let's Avatar
let
Default Re: 94 5spd dx - random squealing? (jxmac2o6)
I'm having the same prob with a 93 dx. Completely random squealing. I narrowed it down to the distributor.
Old Aug 23, 2005 | 07:56 PM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilu &raquo;</TD></TR><TR><TD CLASS="quote">rarely when i drive my car it will make a high pitched squealing noise...i've noticed i can make it stop when i put it in neutral and then put it back in gear, but make sure it's in gear good...it doesn't sound like grinding. just squealing. what's this noise coming from?</TD></TR></TABLE>
What condition is your throwout bearing and clutch in. Are you shifting at high rev's etc. I could help you more, but I need to know more info on when and how it squeal. IM or post here and I know I could help you as I have a large knowledge of these tranny's and in general.
Old Aug 23, 2005 | 08:05 PM
DraconicPenguin's Avatar
Default Re: 94 5spd dx - random squealing? (Bond)
I had a similar problem with my mazda protege, it would randomly start squeeling and would go away as soon as i touched the brakes. I believe it was the brake pads that needed replaced.
good luck
Old Aug 23, 2005 | 09:25 PM
smokee's Avatar
Default Re: 94 5spd dx - random squealing? (Draconic Penguin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Draconic Penguin &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar problem with my mazda protege, it would randomly start squeeling and would go away as soon as i touched the brakes. I believe it was the brake pads that needed replaced.
good luck </TD></TR></TABLE>
yes there are brake squeelers in alot of cars, my old civics had them. they make weird loud random squeeling noises when the brakes get very worn. and they are easy to check as well to verify/eliminate them as the problem.
Old Aug 26, 2005 | 10:46 PM
ilu's Avatar
ilu
it's not brakes, i know what brakes sound like when they're going bad. it's not the AC or anything because i had that problem with my explorer and my friend's caravan did too. this is a different sound. it is coming from either the transmission or the clutch assembly and only happens right after i change gears.
deviant1
25
Oct 19, 2005 07:19 PM
ZexyAccord
Mar 5, 2005 04:17 AM
kupras
Aug 27, 2004 12:31 AM
Slammed95Cord
Nov 27, 2003 02:24 PM
Larkin W.
Aug 9, 2002 01:26 PM
