type r suspension like new?
Old Aug 23, 2005 | 06:07 PM
ekim952522000's Avatar
Default type r suspension like new?
ok guys my type r has 72000 on it and my suspenion feels a little worn out what is needed to make the suspension handle like new again I don't want aftermarket suspension I like it stock.
Im already ordering new shocks.
do i need new springs and bushings to?
what about sway bars?
Old Aug 23, 2005 | 06:38 PM
Bbasso's Avatar
Default Re: type r suspension like new? (ekim952522000)
order new shocks, new springs.
sway bars, don't go bad unless they sustained damage.
get new bushings all around. Consider getting Polyurethane Bushings, they might be a bit harsh but should improve handling a substantial amount.
and re-torque each and every bolt on the caR.
Old Aug 23, 2005 | 06:49 PM
Chris F's Avatar
Default Re: type r suspension like new? (Bbasso)
I'd skip the springs.
Bushings, go nuts!
Old Aug 23, 2005 | 07:07 PM
Kendall's Avatar
Don't forget to check the balance of the wheels and the alignment.
Old Aug 23, 2005 | 08:16 PM
Default Re: (Kendall)
the only bushings I would do is stock or maybe mugen hard rubber. because I don't want to get bumped out of stock autox class.
so springs wear out?
Old Aug 23, 2005 | 08:18 PM
jetydosa's Avatar
25 Year Member
Default Re: (ekim952522000)
Keep the springs and get a set of Koni yellows.
Old Aug 23, 2005 | 08:21 PM
Default Re: (Jetydosa)
I already bought new stock shocks.
Old Aug 23, 2005 | 08:24 PM
jetydosa's Avatar
25 Year Member
Send em back and get some Koni yellows
I wouldnt worry about springs, bushings could be a good idea though. And as others mentioned, a good alignment if you havent had one recently.
Old Aug 23, 2005 | 08:25 PM
Ok are rubber bushings really hard to replace I know poly bushings are a bitch but how hard are oem replacment
Old Aug 24, 2005 | 06:48 AM
00R101's Avatar
Bushings are hard to replace. Does not really matter whether they are rubber or poly. This is a job you probably wasnt to give to a shop to do (and one with experience) Lots of the bushings have to be pressed, cut or torched out and have to be pressed in. Not something that would be fun without a lift.
Also you cannot use the Mugen hard rubber bushings and stay in stock class - only stock bushings will do as replacements (except front sway bar bushings which are free and shock bushings).
OGxruiner
Feb 14, 2011 08:30 AM
BakPil
Honda Civic (2001 - 2005)
Aug 16, 2008 03:44 PM
FallenCow
Mar 5, 2008 12:05 PM
tig3rxiong
Jun 29, 2004 08:30 AM
