WTT: turbo setup for NA motor
Old Aug 23, 2005 | 03:37 PM
sPaRk'iT's Avatar
Default WTT: turbo setup for NA motor
....edited
No crower valvetrain, just cams.
You get this too!
Golden Eagle LS 81mm sleeve block with Ls crank PERFECT just might need honing.
GSR water/oil pumps
Eagle Rods NEW
ACL main bearings NEW
Port and polish Ls head with Crower 402 turbo cams (stock vavletrain) GOOD skunk2 cam gears GOOD
skunk2 manifold GOOD
Dh-racing 74mm GOOD
Garrett T4 A/R .60 oil/water cooled turbo w/ stage 3 turbine NEW
SP manifold with 2.5-3" downpipe (AC ) NEW
Steel braid oil lines NEW
Apexi Hybrid FMIC GOOD
Drag polish pipings GOOD
Precision 550cc saturated injectors NEW
Tial wastegate
Apexi filter NEW
Uberdata base map LS ECU chipped for this setup.
Like i said this setup is nearly done, just need a few more stuff like timing belt, head gasket,bolts etc...and you'll be looking at 400+HP motor. I just want a good running motor and move on with life.
Modified by sPaRk'iT at 12:47 AM 8/24/2005
Modified by sPaRk'iT at 12:49 AM 8/24/2005
Modified by sPaRk'iT at 12:53 AM 8/24/2005
Modified by sPaRk'iT at 10:01 PM 3/19/2006
Modified by sPaRk'iT at 5:06 AM 3/20/2006
Old Aug 24, 2005 | 02:20 PM
sPaRk'iT's Avatar
Default Re: WTT: turbo setup for NA motor (sPaRk'iT)
TTT
Old Aug 24, 2005 | 03:02 PM
new2novas's Avatar
bump....too bad your not closer
Old Aug 25, 2005 | 11:48 AM
sPaRk'iT's Avatar
Default Re: WTT: turbo setup for NA motor (new2novas)
TTT
Old Aug 25, 2005 | 06:41 PM
sPaRk'iT's Avatar
TTT
Old Aug 27, 2005 | 07:37 PM
sPaRk'iT's Avatar
TTT
Old Aug 30, 2005 | 09:50 AM
sPaRk'iT's Avatar
TTT
Old Sep 13, 2005 | 02:02 PM
sPaRk'iT's Avatar
TTT
bubblevic
Jan 28, 2008 11:54 AM
eglslsd
Jul 13, 2007 08:58 PM
Bjorn20
Jun 20, 2006 02:39 PM
sPaRk'iT
Mar 16, 2005 11:33 AM
ExplicitSpeed
Mar 8, 2004 10:59 PM
