I NEED ALARM WIRE HELP! PLEASE REPLY!
Old Aug 23, 2005 | 02:59 PM
sparta904's Avatar
Default deleted
deleted
Old Aug 23, 2005 | 03:45 PM
G-bonic's Avatar
Hijacked
Default Re: I NEED ALARM WIRE HELP! PLEASE REPLY! (sparta904)
wrong thread it should me on audio/video/alarm etc.. thread..
Old Aug 24, 2005 | 02:09 AM
EnjoyTheRideDC2's Avatar
Your Unlock/Lock wires for the Power Locks are in the driver's side kick panel area, Behind the Criuise Control Module, in a fat bundle of wires.
To access those wires, remove the bottom bolt that secures the Module, and pull it up, out of the way.
*The lock wires can only be tested at the Pass. Side lock switch.
Old Aug 24, 2005 | 07:40 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
good luck
Power Lock black/white - driver kick panel
Notes: In the larger of two attached gray plugs in the lower kick near the firewall. If equipped with cruise control, the plugs are behind the module. To access, remove the lower bolt on the bracket holding the module and pull it up out of the way. The lock wires test only with the passenger lock and unlock switch.
Power Unlock black/red - driver kick panel
Modified by DAantagonist at 1:34 PM 8/25/2005
Old Aug 27, 2005 | 07:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sparta904 &raquo;</TD></TR><TR><TD CLASS="quote">what does the cruise control module look like? i didnt see it i looked behind the drivers side kick panel and didnt see anything but a bunch of wires and fuses, i did find the green/red wire all i need to find is the green/white and black one, thanks</TD></TR></TABLE>
The CC Module looks like a tin box thats bolted to the inner kick panel wall. The Green/White wire is in the same fat bunch of wires as the green and red. And no need to find a black wire, just ground the wire that is looking for a ground.
Old Aug 27, 2005 | 09:38 PM
Once you remove the side panel cover, look towards the back of the kick panel area, almost adjacent to the clutch pedal. There will be a rectangular box that you can easily access and a 10mm gold bolt which holds the bottom of it against that wall. Unscrew the bolt, lift the box upwards, and right behind that box will be that fat bundle of wires I've mentioned. I know its tough to tell the wire colors but just have a good light with you. I assure you its in that region.
98greensi
Audio / Security / Video
Sep 28, 2010 08:58 AM
Kavehman
Oct 24, 2006 10:42 AM
sparta904
Sep 4, 2005 08:09 PM
Maverik4k
Sep 21, 2004 09:36 PM
rota426
Nov 10, 2002 03:10 PM
