How do I hook up my cigg lighter, 88 Hatch Std?
Old Aug 23, 2005 | 01:18 PM
VegasEFHB's Avatar
Default How do I hook up my cigg lighter, 88 Hatch Std?
A few months ago, I purchased a complete center console for my 88 Hatch Std from an 89 4dr EX and it came with a lighter with wire attachment. As many of you know, the Std didn't come with ANYTHING in the way of comfort other than a bucket to sit on while you drive unless you gave the dealer your first born child.
This lighter that I acquired has sat in my ride looking very nice but being non functional for several months now. I recently purchased a new lower console part to complete my interior setup, and I would love to have the lighter functional so I can charge my phone while I drive. It has the wiring coming off the socket with the plug, but I have no clue where to plug it in at. Does anybody know where this plug might be hiding, or do I have to cut and make my own connections?
Some items to keep in mind:
1. I do not mind getting creative with my car if I know the result will be better than what I started with
2. I have searched this topic, so please do not tell me that I need to search for the answer
3. I do not know anything about mobile electrical systems let alone how to modify them, so if you have a suggestion on how to "cut up" the wiring, please make it as simple and descriptive as possible
Thanks for looking and helping out!
Old Aug 23, 2005 | 01:31 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: How do I hook up my cigg lighter, 88 Hatch Std? (VegasEFHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegasEFHB &raquo;</TD></TR><TR><TD CLASS="quote"> 89 4dr EX </TD></TR></TABLE>
no such thing. u probaly ment LX. EX were 90 - 91 only.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VegasEFHB &raquo;</TD></TR><TR><TD CLASS="quote">I need to search for the answer!</TD></TR></TABLE>
it has4 wires blk (ground ) any METAL bolt will work - white/grn any power source (radio igniton whatever) red/blk - red thease are for the lights n the ashtray and the light ring around the lighter. (this is EX only ) u can split off from your climate control lights for this.
Old Aug 23, 2005 | 02:14 PM
VegasEFHB's Avatar
Default Re: How do I hook up my cigg lighter, 88 Hatch Std? (DieMaster)
Sorry for the incorrect designation, I am just recalling what I was advised.
Forgive me for seeming ignorant (when it comes to wiring I am very ignorant, hence my plea for help), but it seems that you are telling me to disregard the wiring and clip already attached to the lighter element and extend these to "jimmy-rig" it to the metal body for ground and power? That doesn't seem very safe for me to be doing, as I am sure I will fry my *** when I reconnect the battery .
Do you have the location on the fuse panel that I can connect it to or should I just resign myself to have a professional electrician do this for me?
Old Aug 23, 2005 | 03:34 PM
DieMaster's Avatar
is there a plug there allready? i think there is. if so then just plug it in and your good to go.
just so i dont confuse u w/ more info than u need, is it just a lighter or does it have other red wires with it?
Old Aug 23, 2005 | 03:45 PM
VegasEFHB's Avatar
well... I haven't looked at it recently. it's in the car, and I am at work. I take phone calls for a living, so I can't really go outside and take my console apart to look until I go home tonight. The lighter unit itself has the wiring attached to the female end of the plug, but I can't find the male end anywhere under the dash or behind the radio/climate control area. What would that plug be connected to on the fuse panel?
Old Aug 23, 2005 | 06:17 PM
johnclaunch's Avatar
Your lighter assembly will have a male plug that will plug into the female plug connected to the rear of the ashtray and viola! - lighter. I know this will work because I put in a lighted lighter from an Si and not only does the lighter work, but the lights as well. All the wiring is the same between trim levels.
Old Aug 23, 2005 | 06:24 PM
VegasEFHB's Avatar
Default Re: How do I hook up my cigg lighter, 88 Hatch Std? (johnclaunch)
That is what I thought, but where is the male end??????
Is it bunched with the climate control stuff or tied in someplace else? I have looked for it, but I couldn't see it.
Old Aug 24, 2005 | 06:00 PM
There is a hole in the rear of the ashtray metal bracket. In that hole the plastic female plug will be clipped. I had to pull the female out of that hole to make it reach the extra 1" to the male plug.
Old Aug 24, 2005 | 06:10 PM
VegasEFHB's Avatar
There is nothing attached to the metal ashtray frame other than the ashtray itself (and that is filly removable without any clips). There is no light, there is no light ring around the outlet. The only thing above it when installed is the radio wiring, above that the climate control wires. There is NOTHING there to plug it in to.
Old Aug 24, 2005 | 06:24 PM
I will look at mine again, but the wiring is there. It won't be wrapped up so as to be not visible unless a previous owner wrapped it up.
JDMJUNKIEMONKIE
21
May 9, 2011 10:21 AM
ef4real
Jun 20, 2010 03:25 PM
Down Shift Motoring
Dec 29, 2005 11:54 PM
EKfawknRiCER
13
Jun 27, 2005 11:39 PM
Nic
Jan 25, 2005 09:13 AM
