what's my problem...?
Old Aug 23, 2005 | 12:42 PM
jda90's Avatar
Default what's my problem...?
i have a 90 LS with 103+ miles on it. at times it feels weird driving. when i press the gas sometimes it won't accelerate like it should. do i need a valve adjustment or what? speak on it PLEASE. thanks so much...
Old Aug 23, 2005 | 01:32 PM
jda90's Avatar
Default Re: what's my problem...? (riss'anoobie)
can you give me a link maybe to help me out...?
Old Aug 23, 2005 | 01:36 PM
purplegsr's Avatar
You didn't really describe a specific problem, so nobody will be able to give you links or helpful info.
First step is to do a tune-up, you need to change your distributor cap and rotor, sparkplugs, fuel filter, oil, transmission fluid, air filter, check your timing if you haven't already. If you hear clicking/tapping noises coming from the head, you can assume you also need to adjust your valve lash. Go to http://www.c-speedracing.com, g2ic.com, and http://www.team-integra.net for how-tos on various maintenance procedures).
Old Aug 23, 2005 | 01:39 PM
jda90's Avatar
Default Re: what's my problem...? (purplegsr)
thank you...another problem i have when driving is my rpm's will rise and fall quickly when i switch gears, right along with little acceleration.
Old Aug 23, 2005 | 02:51 PM
Sam92Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riss’anoobie &raquo;</TD></TR><TR><TD CLASS="quote">thank you...another problem i have when driving is my rpm's will rise and fall quickly when i switch gears, right along with little acceleration. </TD></TR></TABLE>
You say your rpm's will rise quickly, well, isn't that acceleration? Maybe I am not understanding what you are saying by this. Any chance someone installed a lighter flywheel before you got the car?
You don't state any recent maintenance, so probably a tuneup will bring you back to speed. Also make sure your cat conv isn't clogged, bogging you down.
Old Aug 23, 2005 | 03:19 PM
temp's Avatar
Default Re: what's my problem...? (Sam92Teg)
http://www.g2ic.com
snoop around it
Old Aug 23, 2005 | 03:31 PM
jda90's Avatar
well, what i mean is that the rpm's rise and fall rapidly and repeatedly within a few seconds when i shift to a new gear. you can hear it from my exhaust too.
Old Aug 23, 2005 | 03:39 PM
Racermech's Avatar
at idle, car not in gear. Do the RPM's go up and down?? 750 is a normal idel, do they go up to maybe 1500 then back to 1000 or lower??
Old Aug 23, 2005 | 03:51 PM
jda90's Avatar
Default Re: what's my problem...? (Racermech)
in about 3rd gear, its starts to do this. it'll go from up down almost half then back up then back down. its then after i shift again and press on the gas it won't go any faster. it'll stay at the same speed, and pressing the gas harder does nothing either.
Old Aug 23, 2005 | 06:52 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riss’anoobie &raquo;</TD></TR><TR><TD CLASS="quote">well, what i mean is that the rpm's rise and fall rapidly and repeatedly within a few seconds when i shift to a new gear. you can hear it from my exhaust too. </TD></TR></TABLE>
slipping clutch???
Old Aug 23, 2005 | 08:32 PM
Moogen Powah's Avatar
Default Re: what's my problem...? (benb18a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benb18a &raquo;</TD></TR><TR><TD CLASS="quote">slipping clutch???</TD></TR></TABLE>
That's what I thought initially when the OP said that he would press the gas and the car would not accelerate immediately as it used to.
Old Aug 24, 2005 | 07:18 AM
temp's Avatar
i thought that as well, but could be vacuume leak also, he isnt describing the problem very well
dude_uuk
Jan 30, 2009 10:41 PM
tirref22
Dec 22, 2004 07:04 AM
typesguy
Aug 19, 2004 07:14 AM
UKPRELUDE
May 17, 2004 08:03 AM
