Suspension & Brakes Theory, alignment, spring rates....
99 si coil overs or koni's
Old Aug 23, 2005 | 12:29 PM
mhx's Avatar
mhx
Default 99 si coil overs or koni's
i have a stock 99 si. I am looking for a clean drop 1in-1.4in max front/rear.
I have no need to adjust the height as long as it stays in the 1-1.4in drop limit..
I used to have a 00 ex with the nuespeed coilovers. I didnt think the ride was harsh or bad at all, but now theres just alot more options out there. From the dyno graphs it looks like the nuespeeds are prob one of the worst?
I wouldnt mind having and adjuster to change the damping. Setting the ride height would be ok but like I said i Just want it in my 1-1.4in drop max range. I like the price on the neuspeeds, i think there 850 new. I would like to stay under 900 price range..
I am a spirted driver I enjoy fun corners on back roads. I autox 1-2 times a year.
what do you suspension pros suggest?
i was thinking maybe koni yellows with eibach pro kit?
Old Aug 23, 2005 | 04:39 PM
chrisw85's Avatar
Koni yellers with GC are $750 with off-the-shelf rates, or $790 with custom rates. Prob your best bet as far as price goes against other systems. 400 front and 325 rear for rates might suit you well. Pair this setup with the GC tophats/mounts, and you'll have a pretty comfortable ride.
I would recommend H&R cupkit but tis about $750+ unless you can find it on sale. It is basically a koni yeller shock with sportline springs. Might as well get koni/gc for that price.
Old Aug 24, 2005 | 07:32 PM
hawjboi's Avatar
your on the right track...stick to the yellows and the pro kit...but if your going to autox later on down the road get the koni/gc setup other than that stick with the pro kit and yellows...
Old Aug 25, 2005 | 07:53 AM
mhx's Avatar
mhx
can you guys think of anything other than koni's that woulf fit my needs
Old Aug 25, 2005 | 10:39 AM
macDelli's Avatar
Default Re: (mhx)
if your lookin for that small of a drop just buy a flat drop spring instead of buyin a full coilover set-up... you only buy coils if you wanna sllaaammm your car. the spring you get in generally bigger for flat drop then coils anyways so itll be a better ride
sh0rt1e67
Mar 4, 2009 04:50 AM
egb18c5
Suspension & Brakes
Dec 26, 2006 06:14 AM
Mr_Moos
Suspension & Brakes
Jan 27, 2006 06:13 PM
TayTeg91
Oct 11, 2004 09:26 PM
2Slow2Content
Aug 5, 2004 09:38 AM
