Suspension & Brakes Theory, alignment, spring rates....
Koni yellow maximum spring rate.... ???
Old Aug 23, 2005 | 11:39 AM
yellowturbo's Avatar
Default Koni yellow maximum spring rate.... ???
Hi I just want to know if they would accept the following rate :
575 front / 675 rear or even a little more.
or they are build for softer spring rate ? Cuz usually ther will be matched with something a lot smoother.
Thanks
Old Aug 23, 2005 | 11:56 AM
slammed_93_hatch's Avatar
Default Re: Koni yellow maximum spring rate.... ??? (yellowturbo)
there is no exact number but most people say that 600lbs is the max that the dampers and properly dampen
Old Aug 24, 2005 | 06:59 AM
thanks for your reply !
any other idea, opinions ?
Old Aug 24, 2005 | 09:42 AM
artifex's Avatar
say it
at those rates you should probably buy the race dampers currently available. 675 is too high for effective damping with the OTS valving, even at full stiff. The race dampers do not come with the lifetime street warranty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch &raquo;</TD></TR><TR><TD CLASS="quote">there is no exact number but most people say that 600lbs is the max that the dampers and properly dampen</TD></TR></TABLE>
c'mon, you know they don't make anything car-related moist.
Old Aug 24, 2005 | 12:04 PM
where I could find some info on the race dampers ?
Do you mean another shock than the yellow one ?
Old Aug 24, 2005 | 01:11 PM
artifex's Avatar
say it
Default Re: (yellowturbo)
no, koni has made production runs of the yellows with spss3 valving, which i believe (don't quote me on this) can handle rates comfortably from 500-1000 lbs/in.
here's the thread CRX Lee made in the RR/AX forum when they came out:
https://honda-tech.com/zerothread?id=1151376
you can probably find a set for a little bit under $1k.
if you decide to go with softer spring rates, user 'chad' is selling some NIB sets he has laying around: https://honda-tech.com/zerothread?id=1348578
Old Aug 24, 2005 | 02:57 PM
shakedown94's Avatar
i just bought spss3 from chris at redshift.
well worth the price and sold my old yellows to make my spss3 same as new yellow sports.
Old Sep 26, 2005 | 07:31 AM
honda13typer's Avatar
Default Re: (shakedown94)
someone once told me you can get them revalved? can someone verify?
Old Sep 26, 2005 | 10:32 AM
Default Re: (honda13typer)
yes, the will need to be sent to koni for revalve
Old Sep 26, 2005 | 07:30 PM
CRX Lee's Avatar
if you get the 8041 RACE units they are already shortened and revalved. If you don't already have Koni Sport units, this will be cheaper and much faster than buying some and having them built to this spec. If you already have some or can get a set for about $100 or so, then it will be cheaper to have them serviced if you haev the time.
Old Sep 27, 2005 | 06:17 AM
Default Re: (CRX Lee)
how much does servicing usually run?
Old Sep 27, 2005 | 12:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Lee &raquo;</TD></TR><TR><TD CLASS="quote">if you get the 8041 RACE units they are already shortened and revalved. If you don't already have Koni Sport units, this will be cheaper and much faster than buying some and having them built to this spec. If you already have some or can get a set for about $100 or so, then it will be cheaper to have them serviced if you haev the time.</TD></TR></TABLE>
I would like to personally thank Lee for his efforts to get the 8041 to market. Hope it is paying off. I'm loving mine.
Old Sep 27, 2005 | 01:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda13typer &raquo;</TD></TR><TR><TD CLASS="quote">how much does servicing usually run? </TD></TR></TABLE>
thats a brod question, ALOT can be included in the "service" or alittle can.
Old Sep 27, 2005 | 07:38 PM
rockdude14's Avatar
i asked at the runoffs
where they do the service for only the price of parts no labor
they said about 140-160 per shock
but they also had the spss3 shocks for sale at 190 each
it was tempting but i had to pass
bnetkillzone
Suspension & Brakes
75
Feb 15, 2012 11:47 AM
mikeycivic
Suspension & Brakes
Apr 3, 2007 07:29 AM
vinuneuro
Suspension & Brakes
Sep 27, 2006 01:02 PM
DarKStaR5
Feb 3, 2005 06:25 PM
slut
14
Nov 20, 2003 09:11 PM
