trouble idling
Old Aug 23, 2005 | 11:32 AM
boost'dsiR's Avatar
Default trouble idling
my car doesnt want to idle up is there ne wAY it could be running on 3 injectors or the firing order is wrong would it do that the coolint line is blocked off the one going to the the upper water neck for the radiator hose doe that effect any thing
Old Aug 24, 2005 | 09:50 AM
boost'dsiR's Avatar
Default Re: trouble idling (boost'dsiR)
bump any help
Old Aug 25, 2005 | 06:16 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost’dsiR &raquo;</TD></TR><TR><TD CLASS="quote">my car doesnt want to idle up is there ne wAY it could be running on 3 injectors or the firing order is wrong would it do that the coolint line is blocked off the one going to the the upper water neck for the radiator hose doe that effect any thing
</TD></TR></TABLE>That's a pretty random combination of thoughts...
Running on 3 cylinders isn't very subtle. It runs like crap all over, not just at idle. And if you have wiring order wrong that has to be 2 cylinders, even worse.
Which water hose are you talking about? The little hose from the neck over to the reservoir bottle? That can let air in as it heats up & cools down. Then the air will confuse the FITV & AICV, which messes up your idle.
Old Aug 25, 2005 | 11:28 AM
boost'dsiR's Avatar
Default Re: trouble idling (JimBlake)
thanks
eghatchfla
May 4, 2011 01:16 PM
duyfash0
Jun 2, 2007 02:30 PM
1.8EG-T
May 9, 2005 11:22 AM
max8455
Jan 10, 2005 05:04 PM
b18cEF9
Nov 5, 2004 12:44 PM
