Biggest tire size that will fit on a stock Del Sol
Old Aug 23, 2005 | 10:25 AM
ApolloSpeed's Avatar
Default Biggest tire size that will fit on a stock Del Sol
I'm getting some 16"x7 Rota Slipstreams 40 offsets for my DelSol (replacing my 14" steelies).
Just wondering whats the biggest meat I can fit under my car with out modification or "rubbing".
I was thinking of going with some 225/50r or maybe 215/55r
what yall think ?
Old Aug 23, 2005 | 11:08 AM
hoffman4684's Avatar
You can get a 215/55 on there but it will screw up your speedo and tranny.
Old Aug 23, 2005 | 11:19 AM
Default Re: (hoffman4684)
I can fix the speedo.....i think its possible......I just wanna know about any clearance or rubbing issues.
Old Aug 23, 2005 | 12:23 PM
Falqon's Avatar
Default Re: (ApolloSpeed)
215 might rub at extreme turns, I'm running 205 with no rubs at all.
Old Aug 23, 2005 | 12:32 PM
Default Re: (Falqon)
205/ 50R's ???
so maybe 225/50 will not rub too much ?
uh.....yeah, I think a bigger tire size will help my gas mileage to on the highway.....
I run about 3900 rpm's @ 70mph currently!!!!!
Old Aug 23, 2005 | 12:33 PM
nub.96ek's Avatar
My friend uses 225/45/16 on Mugen wheels [not sure of the offset] and it doesn't rub at all. Check http://www.kingmotorsports.com for the offset of MF8/MF10. They also look wide as hell... which looks good as hell!
Old Aug 23, 2005 | 01:11 PM
Del Sol SiR's Avatar
Default Re: Biggest tire size that will fit on a stock Del Sol (ApolloSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed &raquo;</TD></TR><TR><TD CLASS="quote">I'm getting some 16"x7 Rota Slipstreams 40 offsets for my DelSol (replacing my 14" steelies).
what yall think ? </TD></TR></TABLE>
is this on stock shocks and stock springs ?
I use Yokohama AVS ES100 Tires 205/40/16 w/ tein coil overs
Old Aug 23, 2005 | 01:14 PM
Default Re: Biggest tire size that will fit on a stock Del Sol (DELSOLEMITE)
YES....stock setup....
Old Aug 23, 2005 | 01:21 PM
IHateJDM's Avatar
i dont' see you having any problems on stock ride height with either 205 55 or 215 50.
Old Aug 23, 2005 | 02:06 PM
Bong29007's Avatar
Default Re: Biggest tire size that will fit on a stock Del Sol (IHateJDM)
Old Aug 23, 2005 | 02:10 PM
Default Re: Biggest tire size that will fit on a stock Del Sol (Bong29007)
hmmmm.....I wanna try 225/50 maybe.....get my gear ratio up for highway driving
Old Aug 24, 2005 | 03:40 PM
jdmturbosol's Avatar
i have 225x15 bfg's on my sol for daily driving and they dont rub
my 24.5"x9x13 slicks dont rub either
betta285
May 14, 2007 06:10 AM
Elwuudz
May 2, 2006 11:32 PM
pearl
Mar 31, 2006 07:59 PM
dustinsterk
Jan 7, 2004 08:20 AM
delsol3982
Dec 29, 2003 08:48 PM
