who's the CR specialist??
Old Feb 24, 2002 | 02:53 PM
non-VTEC's Avatar
Default who's the CR specialist??
i asked this in the ITR section but i dont get any replies. i'm not to good with calculating numbers. so i need a little help.
the engine is a B20Z
84.5mm cylinder bores
Stock 3 layer headgasket
rod to stroke ratio is 1.539
46.2cc cylinder head chambers
customs JE pistions with a compression height of 1.181
dome height .120
if someone can take the time and figure out what the static CR would be in this engine i would really appreciate it. and try to be as accurate as possible if you can.
thanks
Old Feb 24, 2002 | 07:11 PM
HidPerf's Avatar
Default Re: who's the CR specialist?? (non-VTEC)
Go to http://www.performancetrends.com and d'load the demo of this program. I think it might help although I don't know if all the functions you need will be there.
Old Feb 27, 2002 | 07:59 AM
GM2000ITR's Avatar
New User
MIKE K should be able to help you out if he has a lil' time. Ask him!
thecruzs2007@yahoo.com
Sep 27, 2009 12:08 PM
blackhbkid
Jan 29, 2009 08:21 AM
lv2exl8
Jun 27, 2006 09:03 PM
non-VTEC
Feb 27, 2002 01:37 PM
