Master cylinder/Brake line Question
Old Aug 23, 2005 | 10:04 AM
IHateJDM's Avatar
Default Master cylinder/Brake line Question
I was attempting to replace my brake booster and master cylinder this past weekend, but ran into a problem. My car is 93 del sol, and the BB/MC is from a 94 teg (1" MC). I found out that one of the brake line fittings for the master cylinder needs to be a larger than the fittings my sol has. I found the brake line I need at this site below (number 9 in pic), but since the line runs from the mc to abs (which I don't have) I was wondering if anyone could tell me what size the fitting on the abs side of the brake line is. It needs to fit into a 40/40 proportioning valve (also from teg). If anyone knows where I can buy metric brass fittings online, that would work too. Thanks.
http://www.acuraautomotivepart...y.jsp
Old Aug 23, 2005 | 10:20 AM
Luserkid's Avatar
Default Re: Master cylinder/Brake line Question (IHateJDM)
Perfect thread as i was having this debate with my friend. You have a ABS LS MC/BB? Your 100% you need to reflare? Just making sure.
Sorry i dont know the pitch size.
Also bad link.
Old Aug 23, 2005 | 10:27 AM
IHateJDM's Avatar
Default Re: Master cylinder/Brake line Question (Luserkid)
Yep, 100% sure that the fitting on the stock line is too small. I had already installed the brake booster and master cylinder before realizing this (had to take apart my intake manifold to get it to fit too, damn H). I was just hoping that I could buy this line in the pic (should work now), and just rebend it to the proportioning valve. The only problem I would have is if the fitting on the abs side was the same size as the fitting on the MC side, then it wouldn't fit my proportioning valve. I know someone's been through this before, and knows what I need.
Old Aug 23, 2005 | 10:30 AM
pdiggitydogg's Avatar
If all you need is 1 fitting (maybe 2 for 2 lines), buy it, cut the fitting off and install them on your old lines, relfaring (it is a double flare, btw)
I dont know the size of the abs fitting either.....
I know for a fact that the autozone near me has brass metric and sae brake fittings, Im sure yours does too.......for when you get the size
Old Aug 23, 2005 | 10:37 AM
IHateJDM's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">
I know for a fact that the autozone near me has brass metric and sae brake fittings, Im sure yours does too.......for when you get the size </TD></TR></TABLE>
They don't here. Autozone, napa, and advance have standard size fittings only here. No metric. I went everywhere before swapping the stock bb/mc back in. I guess I'll have to buy the line, and hope it works. If not, I can chop the fitting off the end and get the flare kit to move the fitting on my stock line.
rebabal
11
Jul 11, 2016 06:17 PM
raverx3m
Suspension & Brakes
Aug 25, 2013 08:29 AM
vietnamezerice
Mar 24, 2008 11:09 PM
Jeff_B
Jan 20, 2007 12:18 PM
JohnnieChimpo
Jun 9, 2004 12:55 AM
