Valve Cover Gastket
Old Aug 23, 2005 | 09:17 AM
IlIkEg's's Avatar
Default Valve Cover Gastket
Is it really necessary to replace this everytime u remove your valve cover?
Old Aug 23, 2005 | 09:19 AM
Sleepy_Red_hatch's Avatar
Default Re: Valve Cover Gastket (IlIkEg's)
99% of the time that you take it off, it breaks. so yes
Old Aug 23, 2005 | 09:45 AM
1.8EG-T's Avatar
Default Re: Valve Cover Gastket (Sleepy_Red_hatch)
Just be careful with it, and clean it off good.
Old Aug 23, 2005 | 09:51 AM
komat's Avatar
nope only if its in bad shape
but make sure to use some hondabond ont he corners
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">99% of the time that you take it off, it breaks. so yes</TD></TR></TABLE>
i removed my gasket over 10times still havnt ripped once
either you are ripping them off too fast or you using some pos gasket that isnt oem specs
Old Aug 23, 2005 | 10:01 AM
i kHaNhz's Avatar
Yeah ... make sure you don't rip it or anything, but if it leaks oil or the gasket is rock hard ... then I advise you change it.
Old Aug 23, 2005 | 10:05 AM
EK k kay's Avatar
Default Re: (ikhanhz)
It's not like you torque down the valve cover very tightly anyway. As long as it's not damaged you can still reuse it.
bigt81187
Jul 16, 2007 07:41 AM
Shaguar47
May 28, 2007 08:47 AM
RGK500
Feb 15, 2007 08:23 PM
92ehatch
Jan 3, 2006 08:52 AM
mickey513
Mar 29, 2002 10:16 AM
