Check engine
Old Aug 23, 2005 | 07:56 AM
silverboost's Avatar
Default Check engine
my friends check engine light went on in his stock 98 coupe, the code is low voltage current to the O2 sensor, he put an O2 simulator on but light still goes on , how could this be cured? bad sensor?
Old Aug 23, 2005 | 08:01 AM
IHateJDM's Avatar
Default Re: Check engine (silverboost)
probably replace the sensor, or try cleaning it with carb cleaner. He didn't try the o2 sim on the primary o2, did he?
Old Aug 23, 2005 | 09:09 AM
Default Re: Check engine (IHateJDM)
yea he said it was the O2 sensor on theaders
Old Aug 23, 2005 | 09:11 AM
IHateJDM's Avatar
you can't simulate the primary, o2 sims should only be used on secondary o2s. he should swap the secondary o2 to the primary spot and wire the sim in at the secondary location.
perpetualburn
May 16, 2007 06:49 PM
Lude_with_an_H22_Attitude
Nov 3, 2005 02:22 PM
adrenajunky
Oct 13, 2004 06:18 PM
CEC76
Feb 25, 2002 10:20 AM
