Question about integra cluster
I noticed that you cant mix and match 94-01 integra cluster. I know that 00-01 is different then the rest and my question was, is it difficult to change the green film on the back of one cluster to another to make everything work correct? Is it easy to damage the film and ruin the whole cluster all together? I wanted to try this, but someone told me i would just mess it up and be stuck with two broken clusters. If anyone has done this i would really appreciate your advice. Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmvtec28 »</TD></TR><TR><TD CLASS="quote">Don't pull the green film, just swap the individual gauges...</TD></TR></TABLE>
you also have to swap the 2 films on the right side of the cluster if your looking right at it for the seatbelt light and abs light
I had a JDM 98spec ITR cluster in my 97 GSR, it worked perfectly, no mods. That cluster was then put into a 95 GSR, and also worked perfectly. Didnt have to switch or swap anything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94rs-turbo »</TD></TR><TR><TD CLASS="quote">
you also have to swap the 2 films on the right side of the cluster if your looking right at it for the seatbelt light and abs light</TD></TR></TABLE>
What he said.. they just pop right out with a little pressure from your index finger, but if you feel like swapping the green circuit film thing, be my guest, I suppose that would work as well.
you also have to swap the 2 films on the right side of the cluster if your looking right at it for the seatbelt light and abs light</TD></TR></TABLE>What he said.. they just pop right out with a little pressure from your index finger, but if you feel like swapping the green circuit film thing, be my guest, I suppose that would work as well.
si_motor_spt
17
Dec 8, 2007 02:55 PM
