Wire Harness question for a H series swap in an EK
Old Aug 22, 2005 | 07:25 PM
PrecisionH23a's Avatar
Default Wire Harness question for a H series swap in an EK
I know that I am supposed to run a obd2a harness then simply convert a few plugs to fit on the obd1 H series engine. Then use the obd2a-obd1 conversion harness for the ecu.
Well my problem is I do not have a wire harness but do however have a complete H23a harness.... the engine part as well as the part that goes to the ECU. How hard would it be to run a complete obd1 harness in this set-up and what exactly would need to be done to pull this off so everything functions properly?
The only problem I see is getting everything ran properly for the gauge cluster. If it's more problems than it's worth I'll just run a complete obd2a harness with the conversion harness for the EMS.
Zack Tieleman
May 21, 2024 06:44 PM
therest
Nov 13, 2012 03:41 AM
EF8DayDreamer
Mar 21, 2012 11:52 AM
civicex442
Dec 2, 2007 07:38 AM
Stroker
Dec 10, 2003 06:32 AM
