Suspension & Brakes Theory, alignment, spring rates....
lower control arms?
Old Aug 22, 2005 | 07:18 PM
Civic97s's Avatar
Default lower control arms?
what do they do like the after market ones
my freind said they toe out the wheels
does anyone have before and after pics or just pics of the result of them
and i am a auto xer and also a daily driver
are they for me?
Old Aug 22, 2005 | 07:36 PM
PIC Performance's Avatar
Default Re: lower control arms? (Civic97s)
LCA's don't have very much performance benefit, unless you consider the roughly 2.5lbs of unsprung weight savings on either side (edit: I am talking about ones that are made of aluminum alloy), and the minimization of unwanted suspension deflection with some better-than-stock bushings it seems. They are useful as replacement for the stockers when installations go bad, and bolts become seized inside the bushings of the stock lca's. The majority of aftermarket LCA's are the same length as stock I think, so using them instead of stock pieces would not affect your camber or toe.
They are an optional piece, with some benefits, but nothing dramatic.
Old Aug 22, 2005 | 07:56 PM
Civic97s's Avatar
Default Re: lower control arms? (Noob4life)
any pics?
Old Aug 22, 2005 | 08:00 PM
.special ed.'s Avatar
after i installed my omnipower LCAs, i got an alignment and the rear toe was kinda off, but it was probably that way with the stock LCAs too.
i just got them because my bolts seized up inside the stock LCAs.
Old Aug 22, 2005 | 08:03 PM
My car riding on some older LCA's I had picked up while in Taiwan.
Another shot:
Old Aug 23, 2005 | 02:54 PM
ohjolt2's Avatar
Just dont get the short ones, their for ricers trying to run dubs with out rubbing. they will narrow your rear track. In fact dont get any thing but the function 7. the rest dont appeal to me.
Old Aug 24, 2005 | 09:08 AM
Tornadom's Avatar
Default Re: (ohjolt2)
Function7
Old Aug 29, 2005 | 07:57 AM
DavidR's Avatar
There are some pics of Function7 LCAs in this thread.
https://honda-tech.com/zerothread?id=1353544
Old Aug 29, 2005 | 09:52 AM
DC4_MADMAN's Avatar
Default Re: lower control arms? (DavidR)
So you dont have to sift through pics, although his are cleaner.
Old Aug 29, 2005 | 01:53 PM
vtecpoweredsol's Avatar
i got new lca's and my toe out is horrible i had about 15-20% tread on my azenis and the right rear was so bad that the tire just blew out today after roughly 600 miles
Old Aug 29, 2005 | 02:02 PM
MattD@Stoptech's Avatar
Default Re: (vtecpoweredsol)
You should have gotten an alignment...
Old Aug 29, 2005 | 07:57 PM
Default Re: (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">You should have gotten an alignment...</TD></TR></TABLE>
i did, need more adjustment for toe tho, wouldnt go into spec
Old Aug 29, 2005 | 09:29 PM
DavidR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecpoweredsol &raquo;</TD></TR><TR><TD CLASS="quote">i got new lca's and my toe out is horrible i had about 15-20% tread on my azenis and the right rear was so bad that the tire just blew out today after roughly 600 miles</TD></TR></TABLE>
What arms did you purchase?
Old Aug 29, 2005 | 09:53 PM
slammed_93_hatch's Avatar
Default Re: (DavidR)
he is massivly confused, and being miss-informed.
https://honda-tech.com/zerothread?id=1354943
Old Aug 30, 2005 | 12:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR &raquo;</TD></TR><TR><TD CLASS="quote">What arms did you purchase?</TD></TR></TABLE>
the new omni-power 1s
Old Aug 30, 2005 | 12:21 PM
DavidR's Avatar
Sounds like you had bend trailing arm, or perhaps a bent rear crossmember.
Old Aug 30, 2005 | 04:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavidR &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you had bend trailing arm, or perhaps a bent rear crossmember. </TD></TR></TABLE>
no, i was right, i figured it out, they are shorter than oem 1s... just look at that thread now https://honda-tech.com/zero...54943
Old Aug 30, 2005 | 05:45 PM
DavidR's Avatar
no, i was right, i figured it out, they are shorter than oem 1s... just look at that thread now https://honda-tech.com/zero...54943</TD></TR></TABLE>
Meaning you took them off, dropped a bolt in each bushing and lined it up with the stock arm to compare length? I'd like a pic of that!
Old Sep 6, 2005 | 02:57 AM
khabi khabi's Avatar
maybe you have ek arms on a non ek chassis?
Old Sep 6, 2005 | 02:58 AM
Default Re: lower control arms? (khabi khabi)
or for that matter eg arms on an ek chassis?
Old Sep 11, 2005 | 01:19 PM
effects66's Avatar
Just wondering how much the LCA's are (function7) and how to get a pair
Old Sep 12, 2005 | 06:53 PM
ebay,go to function 7 ebay store or just search" rear lower control arms civic"
Old Sep 12, 2005 | 07:49 PM
DavidR's Avatar
I've already contacted him, thanks! (I sell them for a little cheaper than F7 does).
blackccoupe
Sep 7, 2009 07:18 AM
matt1982
Mar 17, 2007 09:45 AM
cartel420
Oct 19, 2006 09:22 PM
AMLS4dr200whp
Suspension & Brakes
Dec 6, 2005 07:15 PM
