Why doesn't it fit
I got an 96 LS (auto), for a 96 dx coupe (auto). But I try and try, and the tranny seems to be either longer or something, because is not sitting in place. I try using the civic mount on the tranny, because my car doesn't have the piece for the tranny like the integra. So I need a solution, can somebody help me.
well the top tranny mount is different, and I can't use it, because de integra has like a bracket welded to the chassis and the mount you screw it to the tranny. Meanwhile, the civic has the mount screwed to the chassis, and the bracket on the tranny. I tried and looked around and it doen't fit. You know if any company sell the bracket to adapt the mount.?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG »</TD></TR><TR><TD CLASS="quote">um maybe cause there tottally different motors. do you have a stock motor in you dx??</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatsMyEG »</TD></TR><TR><TD CLASS="quote">I got an 96 LS (auto), for a 96 dx coupe (auto). </TD></TR></TABLE>
Ok, let me refrase this. I have a 96 civic coupe (automatic), and I bought an 96 integra LS engine (automatic){complete swap}. It starts and everything is running great, but I need to know if there is an adapter around there that I can use. Why?, because the upper transmission mounts are opposite to each other on the B and D series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by impazzi »</TD></TR><TR><TD CLASS="quote">Ok, let me refrase this. I have a 96 civic coupe (automatic), and I bought an 96 integra LS engine (automatic){complete swap}. It starts and everything is running great, but I need to know if there is an adapter around there that I can use. Why?, because the upper transmission mounts are opposite to each other on the B and D series.</TD></TR></TABLE>
You will most likely have to make you own mount on the frame rail... Get two pieces of 1/4" steel plates and weld them in where you want the tranny to sit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtle-eg »</TD></TR><TR><TD CLASS="quote">
You will most likely have to make you own mount on the frame rail... Get two pieces of 1/4" steel plates and weld them in where you want the tranny to sit.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">you need an integra rear mount</TD></TR></TABLE>
No for the 96-00 civics its a rear bracket from a 99-00 civic si, the teg rear bracket will not work. If this was a 92-95 civic then the teg one would be right
jdmstockeg6
Oct 5, 2007 10:59 PM
