another a/c swap question
Old Aug 22, 2005 | 06:14 PM
dscivicdx's Avatar
Default another a/c swap question
b18b swapped into a 95 dx coupe. using the b18b compressor, will the lines from a 97 del sol vtec run from the b-series compressor to my condenser?
thanks in advance!
Old Aug 22, 2005 | 06:18 PM
REEMB18C1's Avatar
Default Re: another a/c swap question (dscivicdx)
I HAVE THE SAME SWAP IN MY COUPE IM RUNNIN MY CIVIC LINES WITH A INTEG COMPRESSOR I FLEXED THE HOSES BUT WORD IS U CAN USE AN CRV AC BRACKET AND USE UR STOCK CIVIC COMPRESSOR TO RUN IT ....
Old Aug 22, 2005 | 08:01 PM
dscivicdx's Avatar
Default Re: another a/c swap question (REEMB18C1)
yeah i heard the same thing, but my civic compressor was bad and the teg one was new and came with the swap, so i figured i would try and get it going if i could.
Old Aug 22, 2005 | 08:14 PM
1.8EG-T's Avatar
Will the b18b compressor even fit? I always have used the del sol/crv bracket, d series compressor and the lines from the car to fit.
Old Aug 23, 2005 | 10:11 AM
dscivicdx's Avatar
Default Re: another a/c swap question (1.8EG-T)
yeah it fits. i dont have p.s. so im thinkin thats where im getting the extra room?
Old Aug 23, 2005 | 10:21 AM
1.8EG-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dscivicdx &raquo;</TD></TR><TR><TD CLASS="quote">yeah it fits. i dont have p.s. so im thinkin thats where im getting the extra room?
Does all four bolts on the compressor screw into the mount? I am almost certain though, for the d series lines to work, you need to use a d series compressor.
Old Aug 23, 2005 | 11:12 AM
dscivicdx's Avatar
yeah the compressor is on the original teg bracket bolted to the motor. i was wondering if the suction and discharge lines from the del sol with the b16 would work to run from the compressor to the condenser. they are different part numbers from the stock dx lines, so i was thinking they might work as both the teg and del sol vtec compressors are ND's and not the d-series Sanden compressor. im basically hoping that i just have to buy these lines, rather than buy a whole new compressor and the lines(i dont have the stock dx suction and discharge lines either)
Old Aug 23, 2005 | 08:52 PM
1.8EG-T's Avatar
You can also go to an AC shop and have them make an adaptor, or a complete new set of lines that are out of the way.
mikester1222
Oct 29, 2007 06:10 PM
russjameson
Oct 17, 2005 04:47 PM
honda20
May 26, 2005 08:23 PM
Edwardo911
Jul 14, 2004 01:59 PM
b18bme
Apr 12, 2004 11:29 AM
