D Tranny Problems
I have read of a few tranny problems on this page, but non seem like mine.....I have a D series w/ a rps turbo clutch and fidanza lightweight flywheel. Just about everytime I go into second gear it will grind and go right out. Some times it will jerk pretty bad and throw the shifter out of the gear. There is also a lot of play in the shifter. Im not sure if the play is from the mounts and the 2nd gear problem is the linkage or syncros. But would it even be worth paying the money to get **** replaced. Or should i just try and find a used D tranny.
first thing you learn about 88-00 SOHC trannys, if a person blames the synchros, he has no freaking clue what he is talking about.
I've had to replace just 4 synchros in my tranny which I ABUSE greatly. One was replaced due to a shifter fork breakage.........
The other 3 from 6 years of HARD racing on this tranny.
lacking vtec
Mar 29, 2007 03:29 AM
