which one of these is the fan switch?
Old Aug 22, 2005 | 02:41 PM
*Boostwerks*'s Avatar
Default which one of these is the fan switch?
Just doing some maintence on my mother's 96 accord LX. I'm a 4th gen guy, so all these sensors confuse me...
TIA!
Bryson
Old Aug 22, 2005 | 04:39 PM
Old Aug 22, 2005 | 04:57 PM
bill-71SS's Avatar
Default Re: (Bryson)
23
Old Aug 22, 2005 | 06:12 PM
ok, 23 is just the gasket, but thanks! I know which one you meant...
Old Aug 23, 2005 | 06:01 AM
JimBlake's Avatar
Also #18 in the upper hose nozzle? Apparently '96 still has the fan timer module with 2 fan switches. I think that other one has a different setpoint & it's active after you turn off the engine.
Old Aug 23, 2005 | 06:51 AM
jmd471's Avatar
Default Re: (JimBlake)
23 or 24/whatever...you can test that switch by using a multitestor and boiling water...
Old Aug 23, 2005 | 09:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">Also #18 in the upper hose nozzle? Apparently '96 still has the fan timer module with 2 fan switches. I think that other one has a different setpoint & it's active after you turn off the engine.
Thats exactly the problem. The car will continue to run the fan for probubly 5 minutes after the car has been shut off. It's not overheating by anymeans. So which switch is what?
Old Aug 23, 2005 | 09:39 AM
cchhrriiiss's Avatar
Edit:
Just realized im a dumbass.
Jim
Modified by ChrisColeman at 7:33 PM 8/25/2005
Modified by ChrisColeman at 7:34 PM 8/25/2005
Old Aug 24, 2005 | 03:46 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson &raquo;</TD></TR><TR><TD CLASS="quote">Thats exactly the problem. The car will continue to run the fan for probubly 5 minutes after the car has been shut off. It's not overheating by anymeans. So which switch is what? </TD></TR></TABLE>All I've seen of a wiring drawing for that type of system, I didn't see the text of that section of the Helm book. Both fan switches are wired into the timer module & it wasn't clear from the drawing what kind of logic was going on inside the timer. But I think it's either #18 or it's both together.
Check both of those switches for continuity between the 2 contacts. When it's cold, I think they should be open. Probably one of those is stuck closed, which would run the fan 'forever'; but the timer module (correctly) shuts it off after a few minutes.
On that picture #10 looks like just a hose nozzle. I suppose the fan timer module is in one of the fuseboxes, it'll look like a relay. But it's a separate component from the fan relays.
Just for grins, #19 is the temperature sensor for the ECU, #15 is the sender for the dashboard temperature gauge. #16 & #17 are both fan switches, you'll have one or the other depending on what model. Honda shares those pictures among several versions of the car.
Grundell
Oct 15, 2015 05:29 AM
dirty_sancho
May 12, 2010 07:36 AM
BryanPendleton
Jul 26, 2006 07:31 PM
bon3
Jun 21, 2005 06:00 PM
