AC problem
i was driving to the store earlier and my ac all of the sudden got hot..it was cold before don't know whats wrong. I was just wondering if you turnn on the AC does both fan go on..I turn on the car and ac and now no fan is spinning..only the one on the right spins when its hot..is the one on the left located near the AC suppose to spin when i turn on the AC...i was told that with header this can cause your ac to stop running..Any Help Would Be appreciated...
Not sure if both fans should be energized but you need a condenser fan to reject heat from the condenser. The smaller of the two should be on when the ac is on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 »</TD></TR><TR><TD CLASS="quote">is there fuses where i can check if so where??</TD></TR></TABLE>
check fuse boxes under the dash and under the hood.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxsi8 »</TD></TR><TR><TD CLASS="quote">okay how can I fix an ac leak!~</TD></TR></TABLE>
locate it, seal it, replace drier, pull a vacuum, and charge.
broken_honda
Jun 26, 2018 03:17 PM
94_civicEx
Honda Civic (2006 - 2015)
Jun 13, 2014 12:28 AM
bxstylez
Oct 7, 2005 05:12 PM
