Gsr turns over but wont start
Old Feb 24, 2002 | 11:25 AM
integra15's Avatar
Default Gsr turns over but wont start
I need some help here, I was backing out of a parting spot and stalled my car by mistake. When I tried to start it up again, It would turn over well but not fire up. The car is old, 1994 gsr w/129k, so I think it could be a fuel thing maybe? I know my battery, plugs and wires are good so what could it be?
Old Feb 24, 2002 | 12:50 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: Gsr turns over but wont start (Integra13)
try replacing the fuel pump and check out the fuel lines as well.
[Modified by JSM, 3:53 PM 2/24/2002]
Old Feb 24, 2002 | 02:42 PM
integra15's Avatar
Old Feb 24, 2002 | 04:33 PM
fOmaNPu's Avatar
Definitely sounds like something with the fuel? Maybe you got some water (or sugar ) in your tank? I had the same problem when I first got my car...but it was just me shifting so horribly that the wire was coming off of the battery. A wrench and hammer sure fixed that ^^
Old Feb 24, 2002 | 05:44 PM
ARunto's Avatar
Default Re: Gsr turns over but wont start (fOmaNPu)
Check your ignition coil
-Alan
Old Feb 26, 2002 | 07:12 PM
GTM's Avatar
GTM
You either have a fuel or spark problem. Here's how to check:
1. Unplug 1 plug wire at a time and put the tip of it near any chassis ground.
2. Have a friend crank the car and check for arc.
3. If all 4 cylinders have spark, then either replace the fuel pump, or fuel pump relay.
Old Feb 26, 2002 | 07:36 PM
SweetChin's Avatar
Default Re: Gsr turns over but wont start (GTM)
yeah check for spark by pulling the plug wires...if your getting spark then go down to your fuel filter and crack that little screw loose to see if your getting fuel...most likly your not getting spark from the coil or ignitor..its a common thing with hondas and acuras...if you have both spark and fuel...then the only thing i can think of is maybe the fuse for the ecu...i know one time i took out my fuse for the ecu and forgot to put it back and all my car did was crank...hth
Old Feb 26, 2002 | 07:44 PM
Malice's Avatar
New User
i had this EXACT problem last month
its your ignitor! replace it. you may have to replace the coil as well. its not cheap!
Old Feb 26, 2002 | 09:00 PM
Dee's Avatar
Dee
Default Re: Gsr turns over but wont start (MaliceGSR)
Ignitor would be my first choice followed closely by a battery that is dying. Before I changed my battery it would register good voltage but could not produce enough cranking amps to start the engine.
Old Feb 26, 2002 | 09:10 PM
Mr. Softee's Avatar
Default Re: Gsr turns over but wont start (drealgsr)
if it wont start... but then starts later.. most likely you are low on oil.
Old Feb 26, 2002 | 10:30 PM
kikkoboyie's Avatar
New User
Default Re: Gsr turns over but wont start (94goldjungsr)
my friend has had the same problem with his mustang.... it turns over, but all it does is make this click click click click click click noise.... tried jumpin the battery, didnt do anything..... same problem or wut? this car only has 17,000 miles on it
Old Feb 27, 2002 | 05:08 AM
speedymon's Avatar
Default Re: Gsr turns over but wont start (kikkoboyie)
Damn my car wouldn't start the other day. What a coincidence..... My spark plugs were gapped to far.
Old Feb 27, 2002 | 05:09 AM
speedymon's Avatar
Maybe because it's a Ford.
Old Feb 27, 2002 | 03:19 PM
kwintegra's Avatar
Default Re: Gsr turns over but wont start (speedymon)
ignitor 193.00 also replace coil 89.00 dealer items. common problem on all hondas. no biggie!!
[Modified by kwintegra, 12:20 AM 2/28/2002]
Old Feb 27, 2002 | 03:39 PM
MachAF's Avatar
Default Re: Gsr turns over but wont start (kwintegra)
Old Feb 27, 2002 | 04:32 PM
kikkoboyie's Avatar
New User
maybe.... but this gsr is having the same problem
Old Feb 27, 2002 | 07:38 PM
SweetChin's Avatar
if the starter is just clicking it would be either a dead battery but you said that you tried to jump it so its mostlikly the starter...a different problem then what hte gsr is going through
Old Feb 28, 2002 | 02:42 PM
dohcsideSi's Avatar
Default Re: Gsr turns over but wont start (SweetChin)
1.ignitor
2.coil
3.main relay (pgm-fi)
4.fuses
not nessesarly in that order
Old Feb 28, 2002 | 04:04 PM
vtecdc2's Avatar
Default Re: Gsr turns over but wont start (dohcsideSi)
i hade the exact same problem, and it turned out to be the cap and coil. good luck
Old Nov 13, 2004 | 07:07 AM
tommymoose's Avatar
Default Re: Gsr turns over but wont start (vtecdc2)
Instead of buying those parts from Acura, would they all be included if I buy a used distributor for about 125 from the classifieds?
drew_kousk
21
Jul 20, 2008 08:25 AM
Red1ine
Apr 2, 2008 07:52 AM
Jabinya
Jul 13, 2007 05:49 AM
yoursupahero09
10
Jan 23, 2007 04:19 AM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
