what happened??
Old Aug 22, 2005 | 11:33 AM
accex951's Avatar
Default what happened??
i was driving my ls/vtec hard and the oil light came on and the next day i poured in some oil and now the thing is making a knocking noise between 3500rpm and 4500rpm... what the hell did i do???
Old Aug 22, 2005 | 11:46 AM
AutoXer's Avatar
Default Re: what happened?? (Senses Fail y0!)
The oil light is not for low oil, it's for low oil pressure. Did you actually check your dipstick, or just add oil in?
Either way, you most likely starved your motor, and it's toast now.
Old Aug 22, 2005 | 12:04 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
Default Re: what happened?? (accex951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accex951 &raquo;</TD></TR><TR><TD CLASS="quote">i was driving my ls/vtec hard and the oil light came on and the next day i poured in some oil and now the thing is making a knocking noise between 3500rpm and 4500rpm... what the hell did i do???</TD></TR></TABLE>Probably the oil pump went or at least is straining to pump the oil. Did you use ARP rod bolts in the LS/VTEC swap? Most likely rod knock in that RPM range. Also make sure your external oil line is nice and tight with no leaks, could easily be losing oil pressure there..
itzyaboyzeem03
Jul 1, 2016 04:40 PM
mtownek9
Apr 1, 2008 01:54 PM
Vtecme92
Jul 10, 2006 06:27 PM
DC_RaceR
Feb 23, 2006 02:00 PM
hondaeg8
Jan 23, 2004 04:31 PM
