Latch on my 00 GSR doesn't lock sometimes... common problem?
Old Aug 22, 2005 | 09:51 AM
RuskeR's Avatar
Default Latch on my 00 GSR doesn't lock sometimes... common problem?
Sometimes when I shut the hatch of my teg, it seems to just bounce and not lock like it should. Doesn't happen too often, but always when I have something in the other hand. If I play with the locking mechanism a few times it seems to "reset" the lock and it then it works fine.
Any idea what is causing this? Just needs to be lubed up? What should I use for that if that's the case?
Thanks guys.
Old Aug 22, 2005 | 10:05 AM
jay_c's Avatar
Default Re: Latch on my 00 GSR doesn't lock sometimes... common problem? (RuskeR)
Normally its the actuator/solenoid that goes out. Never really seen the latch or cylinder be the cause.
Old Aug 22, 2005 | 11:59 AM
crx_88_si's Avatar
Default Re: Latch on my 00 GSR doesn't lock sometimes... common problem? (jay_c)
theres that little lever under the hatch that you slide to open it, sometimes those stick "open". Mine does it once in a while, you just get used to resetting it everytime you open the hatch
Old Aug 22, 2005 | 12:18 PM
alaskan_teg00's Avatar
Default Re: Latch on my 00 GSR doesn't lock sometimes... common problem? (crx_88_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">theres that little lever under the hatch that you slide to open it, sometimes those stick "open". Mine does it once in a while, you just get used to resetting it everytime you open the hatch</TD></TR></TABLE>
Mine does the exact same thing sometimes. I figured that out during the winter season when my locks freeze and the hatch lock is the only one I can use.
Old Aug 22, 2005 | 08:12 PM
RuskeR's Avatar
Will lubing it up make a different?
Old Aug 22, 2005 | 08:19 PM
satintegra's Avatar
Default Re: (RuskeR)
mine was like that too. i took it to acura and they fixed it under warrenty.
Old Aug 22, 2005 | 08:28 PM
conesmasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RuskeR &raquo;</TD></TR><TR><TD CLASS="quote"> Will lubing it up make a different?</TD></TR></TABLE>
Nope, it's just broke. It will eventually stop working overall. Just fork out the money if you want it to work properly.
Old Aug 22, 2005 | 08:30 PM
bigprospect187's Avatar
same here, my hatch has been gay lately and doesnt stay closed the first time.
Old Aug 23, 2005 | 08:48 AM
RuskeR's Avatar
How much does the new assembly cost? Anyone happen to have a part number?
Thanks guys
Old Aug 23, 2005 | 08:53 AM
Johnny Gasparini's Avatar
I didn't ask for a dime.
When the hatch is raised, turn the key to lock and then quickly unlock it. That usually fixes it for a time being.
Old Aug 23, 2005 | 09:40 AM
TunerN00b's Avatar
thundernoodle
Apr 28, 2010 06:35 PM
The_Ricky_Is
Oct 14, 2008 05:41 PM
ericlee303
Aug 9, 2006 06:21 AM
Stationwagon
Dec 11, 2004 10:30 PM
steven975
Oct 5, 2004 10:28 PM
