ac removal?
Old Aug 22, 2005 | 09:22 AM
SomeDude56's Avatar
Default ac removal?
ok so my a.c in my 88 rex (dx) isnt workin and i was wonderin if its ok to just remove all of the equiptment.. and the lines......is this safe?...... thanks
Old Aug 22, 2005 | 01:11 PM
hedtrip's Avatar
Default Re: ac removal? (SomeDude56)
yes it's safe ... when taking the lines off the compressure .. do it slowly so the freon drains slowly & doesn't spray all in your face & ****
Old Aug 22, 2005 | 01:18 PM
CRX Toad's Avatar
Default Re: ac removal? (hedtrip)
When you do it, make sure you get the white bypass tube to it is fairly cheap and that way you don't have to gut the evap box under the dash. That is was I did and then get the little block off grommet so water doesn't get into your car.
Corrected for B16CRXT (grammar police)
Modified by CRX Toad at 9:01 AM 8/23/2005
99sonicbluegsr's Avatar
don't take it out!!! just fix it, A/C is the ****
Old Aug 22, 2005 | 01:26 PM
CRX Toad's Avatar
Default Re: ac removal? (99sonicbluegsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99sonicbluegsr &raquo;</TD></TR><TR><TD CLASS="quote">don't take it out!!! just fix it, A/C is the ****</TD></TR></TABLE>
I also agree with him. Mine came out cause half of it was already missing and the other half was beyond repair.
Old Aug 22, 2005 | 02:04 PM
PURPLETERROR aka BIGMATT's Avatar
I will take your ac system if your getting rid of it
Old Aug 22, 2005 | 02:09 PM
B16CRXT's Avatar
Default Re: ac removal? (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">Why you do it make sure you get the white bypass tube to it is fairly cheap still and that way you don't have to guy the evap box under the dash. That is was I did and then get the little block of grommet so water doesn't get into your car. </TD></TR></TABLE>
sorry. wtf did you just say?
Old Aug 23, 2005 | 04:23 AM
zccr-xsi's Avatar
take it out and sell it unless u paln on like useing a b18 or something then i would fix cause cause ull have enough power to still be fast.but i live in fl and it gets hot as **** here and i hate driving without a/c i sweat my *** off and the windows and sun roof are open.
Old Aug 23, 2005 | 04:56 AM
CRX Toad's Avatar
Default Re: ac removal? (B16CRXT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16CRXT &raquo;</TD></TR><TR><TD CLASS="quote">
sorry. wtf did you just say?</TD></TR></TABLE>
Long day! Thanks for the insight though.
Old Aug 23, 2005 | 03:59 PM
SomeDude56's Avatar
thanks fellas.....not a big a.c. guy less its above 95......and then i have an excuse to go fast so i dont have a ****** heat stroke(lol) and it makes it easier to get into those tight spaces. More of a heat person....heats ok.....being cold sucks ***.
thanks
Old Aug 23, 2005 | 05:36 PM
sam385's Avatar
give a hoot! don't pollute! R-12 is a nasty pollutant
intentionally letting freon out into the atmosphere is like dumping used oil onto the ground. one should, if at all possible, have the freon evacuated by a shop that has reclaiming equipment.
if you are selling the system, cap all hoses, the comp, condenser, and evaporator so contamination by air will be minimized. the old dryer/reservoir should be replaced by the new owner.
Old Aug 23, 2005 | 05:52 PM
B16CRXT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">When you do it, make sure you get the white bypass tube to it is fairly cheap and that way you don't have to gut the evap box under the dash. That is was I did and then get the little block off grommet so water doesn't get into your car.
Modified by CRX Toad at 9:01 AM 8/23/2005</TD></TR></TABLE>
I wasnt being an *** or anything bud. what you said, literally made no sense. I read it like 5 times with little to no comprehension of what you said. Thanks for changing it though makes sense now.
Modified by B16CRXT at 10:11 PM 8/23/2005
Old Aug 23, 2005 | 06:02 PM
drdisco69's Avatar
Default Re: ac removal? (sam385)
R12 isn't any worse for the environment than R134a is. DuPont started all that because they hold the patent on R134a, and would sort of like to sell a lot of it.
R12 <U>is</U> a poison, however, so your best bet is not to be anywhere near it while it's in the atmosphere. Breathing enough of it or getting enough on your skin can kill you. Just FYI...
Old Aug 23, 2005 | 06:21 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
a/c bypass tube:
Old Aug 23, 2005 | 06:26 PM
Rob.'s Avatar
Default Re: ac removal? (88DXCRX)
I took mine out ! I love the feel of the car without it ! Handles so much better in the turns ! minus 45 lbs !
ShinotakuX
Oct 21, 2008 06:03 PM
GraphiteMW
Mar 15, 2007 08:33 AM
661rex89si
14
Oct 27, 2006 04:03 PM
discrete
15
Jun 18, 2005 12:57 PM
4thgenlude
Oct 27, 2004 07:33 PM
