Ball Joints?
I'm replacing all the ball joints in my EG (on the knuckle and arm) and I thinking of getting them from my local Autozone/Advance parts store. I wanted to know if there is any mystery to ball joints? Also, is there a particular brand that I should stay away from?
Just use OEM - the lower is the only one that you can replace ($35), and it is pressed in. The upper is part of the control arm and cannot be replaced separately. The tie rod balljoint is also part of the tie rod, but those are cheap ($35-$40). When you order balljoints, order a few spare boots and clips as well, they will melt and crack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITACRX »</TD></TR><TR><TD CLASS="quote">I'm replacing all the ball joints in my EG (on the knuckle and arm) and I thinking of getting them from my local Autozone/Advance parts store. I wanted to know if there is any mystery to ball joints? Also, is there a particular brand that I should stay away from?</TD></TR></TABLE>
What is making you replace them?
And how much are those balljoints?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BSME »</TD></TR><TR><TD CLASS="quote">Its all about the J's Racing front lower balljoints that relocated the pivot down an inch or so for repositioning of your roll centers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITAIntegraLS »</TD></TR><TR><TD CLASS="quote">And how much are those balljoints?
http://www.aj-racing.com/produ...acing
$316
*thud*
$316
*thud*
I rather get bunch of stock ones and replace them after every race just for fun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
$316
*thud*</TD></TR></TABLE>
$316
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prkiller »</TD></TR><TR><TD CLASS="quote">What is making you replace them?</TD></TR></TABLE>
The reason is because this chassis has 160k miles on it and all the rubber was cracked. So, I wanted to replace anything that's a wear item. The ball joints don't look bad in the upper arm. On the knuckle and tie rod, they don't have very little grease and what is left is crap. So, wanting to be safe than sorry, I wanted to replace them.
RJ,
Thanks for the info. I just goes to show you last time I've replaced ball joints. Oh, writing the check now for the platnium plated, engraved, shiny ball joints as we speak. Right
RJ,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITAIntegraLS »</TD></TR><TR><TD CLASS="quote">I rather get bunch of stock ones and replace them after every race just for fun.
Haha. Me to!
Haha. Me to!
yes too much money for the suspension geometry correction. That is why I will correct my geometry a different way
using stock components.
The benefit is definitely there however, to make the corrections you need because of lowering.
using stock components.The benefit is definitely there however, to make the corrections you need because of lowering.
That made me laugh.
That made me laugh.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KOALA YUMMIES »</TD></TR><TR><TD CLASS="quote">
That made me laugh. </TD></TR></TABLE>
Those J's racing parts are very expensive. I wonder if anyone buys that stuff?
NMJimCRV
Honda CR-V & Element
Oct 13, 2014 08:30 PM
Powered by VTEC
Jan 1, 2008 10:51 AM
MyDragCar
Dec 2, 2004 09:58 PM
