94 Accord cooling fans
My daughter has 94 accord LX 5sp. It overheated she took to a shop they put in antifreez and sent her home. 3 wks later its hot again, I check level it is low, and fans not working. I add coolent bleled air from system and pass side fan works but not driver side. tried both hot sw and ac sw still only pass side working. Is drivers side full time or part time fan?
thanks
JJ
thanks
JJ
the driver side fan is the a/c condensor fan it should work trhe same as the other fan anytime a/c is on, or after engine is warmed up........try this, get a screwdriver and smack the back of the fan if it starts u got a bad motor,, if not chk fuses, relay , if either is bad replace as needed if both ok, chk to make sure u get power and ground at fan connector..if not u got wiring issues,, if you get both u got a bad fan motor
Accordlxnewb
Jul 3, 2016 03:11 AM
Jdmsolutions
Nov 16, 2006 12:47 PM
