Looking for a high-volume oil pump for my D16Z6.
I picked up an oil pump from Autozone and my oil pressure seems pretty low, my Google search didn't yeild any results on a D-series high volume pump, is one available?
I heard high volume pumps cause lots of oil build up in the head or something along those lines....
i would try to find out the problem and fix it...
good luck
good luck
I'm pretty sure the problem is that i used an Autozone cheapie pump, pressure at 1,100RPMs (my idle) is around 15, 30 at cruising RPMs, 50 around 4,000 and 60-65 around redline, cold start is at 85.
I really want the insurance of a high-volume pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x O 16581 72452 5 x »</TD></TR><TR><TD CLASS="quote">Refer to my edit.
I'm running 20psi, i want insurance.</TD></TR></TABLE>
lol
just because you can move the oil into the engine dosent mean it can drain that fast. oit will create more problems than good.
there is nothing wrong with a OEM honda pump. NOT AN AUTOZONE PUMP
never EVER use anything from autozone that is vital to operation of your engine. period.
lol
A-busive
13
Jul 22, 2006 05:07 PM
