thinkin about b18c1 BUT wat tranny options??
Old Aug 21, 2005 | 09:21 PM
myuglycivic's Avatar
Default thinkin about b18c1 BUT wat tranny options??
i was 99% sure i was going to do a b16a2 swap since the package comes with everything to get it installed. but i found a gsr b18c1 engine w/ no tranny or ecu.
so my question is wat are all my tranny options for a b18c1 and which ecu do i need.
thanks
Old Aug 21, 2005 | 09:25 PM
99teggsr's Avatar
Default Re: thinkin about b18c1 BUT wat tranny options?? (myuglycivic)
what year is the gsr swap ? You can use a chipped p28 or a p72 ECU to run that (if its obd1) if its obd2 then you need an obd2 p72.
As for trannys you can use any b series, just stay away from LS trannys as they have very long gears.
Old Aug 21, 2005 | 09:28 PM
its from a 99 gsr. aite so .. i can use ANY b series tranny rite , even a cable tranny will work ? or do i have to get a hydrolic tranny.
Old Aug 21, 2005 | 09:49 PM
Suck my DX's Avatar
yes u can use a cable tranny...it will be easier since u wouldnt have to convert to hydro in ur EF...
Old Aug 21, 2005 | 10:15 PM
Rywire's Avatar
Default Re: thinkin about b18c1 BUT wat tranny options?? (Suck my DX)
I would get a lsd hydro, WAY better!!! And easy to convert with a hasport kit
H-Ridah
Mar 25, 2007 07:32 PM
suspendedHatch
Feb 24, 2007 07:52 AM
Vtec mini
Oct 12, 2006 04:14 PM
hebelect
Jun 14, 2004 11:59 AM
AlphaQup
Oct 12, 2003 01:41 PM
