Help Me ID A Prop Valve!
Old Aug 21, 2005 | 07:13 PM
SpydiR's Avatar
Default Help Me ID A Prop Valve!
hey guys, I just bought a prop valve off a local dude. it's not stamped '4040', but he swears up and down it is mean for civic rear disc conversions and that if I find out otherwise he will replace it for a '4040'. The unit is stamped '1725' in the location the '4040' stamp would be'. in every other aspect the unit appears to be a '4040', save the stamp. there is also one casting mark that says '42' on one end and side of the valve, and on the opposite end and side there's a casting mark with the number '34' on it. help me out guys, trying to get everything together so I can install
Old Aug 22, 2005 | 11:47 AM
SpydiR's Avatar
Default Re: Help Me ID A Prop Valve! (SpydiR)
bump, somebody has to know. is there any significance to this '1725' stamp?
Old Aug 22, 2005 | 12:46 PM
Luserkid's Avatar
92-95? Let me see if i could pull anything out of the helms. Usually for 92-95 there should be the stamp right there. I know nothing of this 1725, part number maybe? 96 and up i have no clue. Let me look though.
Edit: Of course the helms doesnt give out part numbers or discriptions very well and on SLhonda i couldnt even find the ******. Hope someone could help you out better.
Modified by Luserkid at 1:58 PM 8/22/2005
Old Aug 22, 2005 | 01:27 PM
SpydiR's Avatar
Default Re: Help Me ID A Prop Valve! (Luserkid)
lol yep, I'm not one to ask w/out searching either. notice my post count and join date
don't ek prop valves look all crazy? like a crab w/no legs? lol if so, than this is def. an eg valve.
I guess if I don't get an answer in a couple days I'll go harass my boy jason down at gillman honda and see what he's got to say
edit: forgot to say thanks for the help, thanks!
Modified by SpydiR at 8:54 PM 8/22/2005
Old Aug 22, 2005 | 02:30 PM
Relic1's Avatar
like this one?
https://honda-tech.com/zerothread?id=1041525
Old Aug 22, 2005 | 02:38 PM
unknown0001's Avatar
Just to let you know, I went to the wreckers and say a civic Si with rear disks and took the prop valve thinking it's 40/40 but it was 30/40
Old Aug 22, 2005 | 04:01 PM
Lord Helmet's Avatar
Default Re: Help Me ID A Prop Valve! (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner &raquo;</TD></TR><TR><TD CLASS="quote">Just to let you know, I went to the wreckers and say a civic Si with rear disks and took the prop valve thinking it's 40/40 but it was 30/40</TD></TR></TABLE>
Same here I'm using the 30/40 off of a 95 Civic SI on my EJ1
Old Aug 22, 2005 | 05:55 PM
SpydiR's Avatar
Default Re: Help Me ID A Prop Valve! (Lord Helmet)
... man I got burned. he said he would replace it though, so I'll give him a call and see, but he ALSO said he took the valve off the car himself, etc.
to ******* scammers
to ******* ignorance
...dammit.
Old Aug 22, 2005 | 06:33 PM
Targa250R's Avatar
be professional
That's because non-ABS '92-95 Si hatches have 9.5" front brakes. The 4040 valve is for a car with 10.3" fronts.
gorpobr
Nov 9, 2007 03:13 PM
polylawman
Aug 1, 2004 05:28 AM
MintyDip
Nov 10, 2001 07:15 PM
95GS-R
Nov 7, 2001 05:23 PM
