Aftermarket Crank Shaft??
Old Aug 21, 2005 | 07:02 PM
RA217252's Avatar
Default Aftermarket Crank Shaft??
Blew my crank shaft last night in my GSR. Do they make aftermarket ones, or should i stay stock?
Old Aug 21, 2005 | 07:23 PM
non-VTEC's Avatar
Default Re: Aftermarket Crank Shaft?? (sheehan024)
what you mean you blew the crank? chances are if the crank got distroyed (although it would be pretty hard to do that) the entire bottom of the block would probably be fucked too........i would look for a new engine.
but to answer you question yes there is aftermarket cranks avalable. crower, eagle and i thing scat make cranks for hondas now.
Old Aug 21, 2005 | 07:38 PM
shamoo's Avatar
Will you make something up for me please?
How exactly did you blow the crank? Did you spin a bearing? You can always (well, most of the time), have your crank cut/polished/etc. Get new bearings and you're set.
As non-Vtec said, there are aftermarket cranks available, but I would determine what failed first before throwing another crank in there and having the same problem come up.
88crxdxfastwhip
Mar 18, 2007 05:16 AM
hondaeg8
Feb 9, 2004 10:42 AM
flat-blk-HB
Jan 13, 2004 07:26 PM
TheSwift1
May 29, 2002 10:42 AM
